UTEC Timing Map for Vortech
Old Apr 21, 2008 | 10:37 AM
JonnyC's Avatar
JonnyC
Default UTEC Timing Map for Vortech
Well, I'm getting close to firing up my car with the Vortech setup. It's an Si-trim running the 3.33 pulley, w/ UTEC and 650cc injectors and Walbro 255 (bought the kit used, that's why it has the Si-trim). I think I'll be good on playing around with the fuel map by street tuning it, but I'm a little concerned about the timing map.
Since there doesn't seem to be much info on here about a good Vortech timing map (did plenty of searches), I just planned on using one of the TN basemaps from TurboXS's website.
Do you think either of these will work for a base map? I simply want my setup to be safe until I get get it on a dyno and tune for power. I'll definitely be checking to make sure there is no knock across the board, but I'm not too concerned about getting great power off the bat.
Base TN Timing
http://turboxs.com/downloads/350zute...icsbase28d.TXT
Base TN 550cc Timing (quite a bit different)
http://turboxs.com/downloads/350zute...cs550cc28d.TXT
Thanks in advance,
- Jon
Old Apr 21, 2008 | 11:09 AM
str8dum1's Avatar
str8dum1
even if you do knock, the utec retards timing. you can set how sensitive (how many knock counts) before your retard.
i'd use the 1st map.
Obadabot
Jun 18, 2023 11:31 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
