car not idling w/ utec
Old Apr 5, 2008 | 08:36 AM
KarenZ's Avatar
KarenZ
Default car not idling w/ utec
hey guys i need some help.. i have a greddy turbo kit and i am just trying to get it to run so that i can bring it to the tuners.
it starts up like a champ but all of a sudden stumbles and dies.
there is no ecu code that is being thrown. i am currently running the utec and i havent done too much with it other than configure the basemap from utec and copied over the parameter map..
should i be running in open loop mode?
should i be using map or maf right now
same with under load/
thanks
Old Apr 5, 2008 | 08:39 AM
KarenZ's Avatar
KarenZ
also hope you guys can understand this but here is the data log i got back from when i start the car
00 -0.9 0.50 0 00 00 0.00 +È0.0 0.0 ECU. +0.0 0.43
00 -0.9 0.49 0 00 00 0.00 +È0.0 0.0 ECU. +0.0 0.43
00 -1.1 0.50 0 00 00 0.05 +È0.0 0.0 ECU. +0.0 0.37
00 -1.3 0.52 1 00 00 0.00 +È0.0 0.0 ECU. +0.0 0.43
00 -1.3 0.56 0 00 00 52.50 +È0.0 35.2 ECU. +0.0 0.49
00 -2.3 0.66 1 00 00 52.50 -_6.8 22.0 ECU. +0.0 0.50
00 -4.6 0.56 1 00 00 8.88 +15.0 11.8 ECU. +0.0 0.62
00 -7.0 0.88 1 00 00 4.82 +5.3 8.8 ECU. +0.0 0.80
00 -9.0 0.72 19 00 00 3.28 +37.1 6.7 ECU. +0.0 0.80
00 -8.2 1.39 15 00 00 3.20 +47.9 7.0 ECU. +0.0 1.23
3183 -8.4 1.31 1 00 00 7.71 +15.6 19.8 ECU. +0.0 0.76
3069 -10.3 0.82 1 00 00 3.03 +15.0 7.5 ECU. +0.0 0.72
2803 -11.3 0.96 1 00 00 3.03 +14.8 7.1 ECU. +0.0 0.76
2575 -11.9 0.86 1 00 00 2.98 +14.8 5.9 ECU. +0.0 0.72
2394 -11.9 0.84 19 00 00 2.91 +47.0 5.6 ECU. +0.0 0.84
2465 -10.0 1.39 17 00 00 2.84 +46.0 5.5 ECU. +0.0 1.23
2508 -9.0 1.23 1 00 00 2.77 +26.3 5.5 ECU. +0.0 0.66
2365 -10.3 0.68 3 00 00 2.70 +16.9 5.0 ECU. +0.0 0.68
2418 -11.0 0.82 18 00 00 2.63 +45.8 5.0 ECU. +0.0 0.82
2485 -8.9 1.49 22 00 00 2.56 +46.0 5.0 ECU. +0.0 1.33
2095 -6.7 1.31 5 00 00 2.49 +46.2 4.3 ECU. +0.0 0.92
1860 -8.0 1.01 6 00 00 2.42 +44.5 3.9 ECU. +0.0 0.82
1541 -8.4 0.94 19 00 00 2.35 +42.3 3.4 ECU. +0.0 0.92
1225 -5.9 1.31 13 00 00 2.28 +43.7 2.5 ECU. +0.0 1.09
1007 -4.8 1.09 15 00 00 2.99 +41.9 3.2 ECU. +0.0 0.90
713 -3.8 1.15 20 00 00 5.31 +44.1 4.5 ECU. +0.0 1.09
503 -1.8 1.21 0 00 00 5.31 +38.2 6.8 ECU. +0.0 0.72
335 -2.2 0.68 10 00 00 11.97 +38.7 6.8 ECU. +0.0 0.47
294 -1.5 0.74 22 00 00 11.97 +26.8 6.8 ECU. +0.0 0.82
229 -1.1 0.78 0 00 00 11.97 +26.3 6.8 ECU. +0.0 0.58
Old Apr 17, 2008 | 11:40 AM
zmedic16's Avatar
zmedic16
wich base map did u load? and did you load them from turboxs.com? What size injectors?
i currently got my car started with 440cc injectors and the turbonetics 380cc base maps. the car stumbles a little because its running rich but it doesnt die off.
Old Apr 17, 2008 | 12:53 PM
gothchick's Avatar
gothchick
Um, can you post your log in Txt format? Also, do you have AFRs included in the log? I don't see any...
Something like this:
File Type: txt
Old Apr 17, 2008 | 12:59 PM
gothchick's Avatar
gothchick
These massive jumps in factory timing have me a little concerned. That probably wouldn't be much fun to drive even if it ran.
As another thought: With timing that high, I would expect to see knock, which I don't. What are your knock parameters set to?
Old Apr 18, 2008 | 12:07 PM
frankie945's Avatar
frankie945
run open loop fueling and use map , speed denisty mode read the manual over you might miss something I have read it about 4 times.
Old Apr 22, 2008 | 05:42 AM
gothchick's Avatar
gothchick
One more thought: Did you export this from an Excel Spreadsheet? If this is a native data dump - then I have never seen data garbage like what you have at the top of this log unless the firmware somehow got corrupted. A reflash with the current .mot would be a good precaution when in doubt. If that is Excel garbage, then nevermind.
Old Apr 22, 2008 | 11:19 AM
Kdukes's Avatar
Kdukes
Try downloading the dbw file from turboxs. It is for throttle control for drive by wire cars. I had the same problem when I put my turbo in. I called turboxs and that is what they told me to do. As soon as I downloaded the file the car idled fine and had great throttle response.
NissanZcrazy
Nov 2, 2015 06:03 PM
davewo
Apr 10, 2006 09:37 AM
aalzuhair
Jan 31, 2006 06:42 AM
Sharif@Forged
Jan 13, 2006 10:41 AM
RED HOT Z
Jan 8, 2006 02:54 PM
