How to deCipher injector duty cycle?
Old Sep 18, 2008 | 07:30 PM
civic4982's Avatar
civic4982
Default How to deCipher injector duty cycle?
Hey everyone.
I was trying to figure out how to get injector duty cycle from my Cipher cable and attempted to obtain it by using the formula I found on post #12 of this thread in the FI section:
https://my350z.com/forum/forced-indu...kit-w-fmu.html
Does anyone know if this is an accurate way to use the injector pulse and the rpm to obtain the duty cycle percentage value?
Old Sep 18, 2008 | 07:34 PM
civic4982's Avatar
civic4982
% duty cycle = ( pulse width / period )*100
period = 1/[engine speed (rpm) / 60]
With that calculation and changing units considering that the injector pulses listed are in milliseconds (have no units on my cipher so I don't know) I found the following calculation to give me a value that seems logical:
the amount pulse width/ period /100,000
These were the calculations I used.
Old Sep 19, 2008 | 04:47 PM
civic4982's Avatar
civic4982
Does anyone know if this is accurate?
Old Sep 20, 2008 | 02:40 PM
WTX350Z's Avatar
WTX350Z
I thought for sure Uprev would be here to help.....
free bump
Old Sep 20, 2008 | 02:41 PM
civic4982's Avatar
civic4982
yeah but it's the w/end. maybe they'll chime in later next week.
I really hope I did this calculation correctly.
Old Sep 22, 2008 | 05:28 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
RPM x PW / 1200 = %DC
Example: 8500rpm x 10ms / 1200 = 70.8% Duty cycle
Old Sep 22, 2008 | 02:39 PM
PunKidd's Avatar
PunKidd
Yep, Hal's got it. That's the formula I use. You can make that work in excel (or better yet Open Office) pretty easily w/ the Cipher logs.
We've been meaning to add that to Cipher for > a year, just hasn't happened. Now we're working on adding logging and map tracing functionality to the V2 ROM editor, so chances are that's where you will see that functionality finally come to be.
Jared@UpRev.com
Old Sep 22, 2008 | 02:42 PM
civic4982's Avatar
civic4982
great thanks for the verification!
Old Sep 22, 2008 | 05:45 PM
OldManZ350's Avatar
OldManZ350
How will it with the Vortech SplitSecond Box? If the SS Box is modifying the signal will the Cipher read the actual pulse width or not?
Old Sep 22, 2008 | 08:11 PM
civic4982's Avatar
civic4982
If I'm not mistaken your SS Box will modify the signal BEFORE it gets to the engine and the OBDII reads AFTER (as an output) as opposed to reading what the ECU is sending although I'm not 100% certain on this.
Can someone from Uprev verify?
Old Sep 24, 2008 | 09:29 AM
PunKidd's Avatar
PunKidd
I don't know enough about how the SS works. Does it have it's own injector drivers, or is it just modifying the MAF and crank signals?
All I ever do w/ a split second is take it out. Never paid any attention to what signals it was modifying.
Jared@UpRev.com
Old Sep 24, 2008 | 09:36 AM
OldManZ350's Avatar
OldManZ350
It change the signal to MAF
Old Sep 24, 2008 | 01:56 PM
PunKidd's Avatar
PunKidd
As long as the ECU is still the one driving in injectors, then the Cipher data log will be acurate.
Jared@UpRev.com
