injector response or dead time
Old Nov 5, 2008 | 09:54 AM
tony_t's Avatar
tony_t
Default injector response or dead time
does anyone know the dead time for the factory fuel injectors?
Old Nov 9, 2008 | 06:24 AM
Q45tech's Avatar
Q45tech
Depends on applied voltage and fuel viscosity [gasoline production at refinery that hour][temperature].
Don't confuse just electromecahnical opening time as TOTAL LATENCY but add in ramp up based on psi.
Depending on the above variables.
700usecs [@ 12.8 volts measure at injector] would be a good start then you zero in based on hot idle A/F in +- 100 usec increments.
Obadabot
Jun 18, 2023 11:31 PM
