engine mngt with outputs for gauge monitoring
Old Aug 20, 2009 | 08:09 PM
mgrotel's Avatar
mgrotel
Default engine mngt with outputs for gauge monitoring
are there any engine management systems out there that have direct outputs for a/f, nit pressure, fuel pressure? either outputs for gauges or an output with a screen that displays all of the above? this would make wiring much easier. thanks for the help
Old Aug 26, 2009 | 02:18 PM
mgrotel's Avatar
mgrotel
bump...
Old Aug 29, 2009 | 05:15 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
The plug & play Haltech Platinum 350Z ems has a plug and play dash option that I have attached below. All of your standard information such as rpm, coolant temp, air temp, a/f ratio, etc is transmitted to it and can be setup with shift lights, alarm lights, math channels, etc. In addition to that, there is an endless list of plug & play sensors for the dash such as oil pressure, fuel pressure, etc. This Racepak dash (with built in Haltech module) fits nicely in 350Z cubby in the dash.
Old Aug 29, 2009 | 08:04 AM
mgrotel's Avatar
mgrotel
do you have physical dimensions on that thing? i didnt see any on the link
thanks
Old Aug 31, 2009 | 07:55 AM
Dynosty's Avatar
Dynosty
thanks
7.25" x 4"
Here is the setup in our drag car:
Old Aug 31, 2009 | 07:37 PM
rcdash's Avatar
rcdash
Hey Hal, that thing says it has configurable inputs on it. Are those inputs configurable with ECU manager, in axes, etc? In other words, why am I waiting on the input/output box if this has it all?
Old Sep 1, 2009 | 03:08 AM
Dynosty's Avatar
Dynosty
rcdash, inputs into the dash do not echo back into the Haltech. They are for viewing/logging on the dash.
Old Sep 2, 2009 | 06:55 PM
rcdash's Avatar
rcdash
Gotcha - thanks!
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
