Questions...
Old Mar 19, 2010 | 08:38 PM
dmroberson's Avatar
dmroberson
Default Questions...
Ok, so I know I'm probably gonna get ragged on, but I picked up a Unichip. Got it used, from another member, and sent it to Unichip to have them reflash it. They said, since this is the older version, it only holds 1 map. So, they installed the "best" map for my vehicle.
Anyway, install was cake. However, now the Z is really difficult to start. cranks for a while, before finally turning over. And also, my steering is really weird. Not loose when moving at low speed or stopped. It's actually very firm. Seems to loosen up a bit when moving.
Assuming that's not normal, what can I do about it? Other than send the Unichip back, and get something else.
Thanks.
Old Mar 19, 2010 | 09:51 PM
So how does Unichip effect steering?
What steering parameters can Unichip alter?
Old Mar 19, 2010 | 10:08 PM
dmroberson's Avatar
dmroberson
Idk. Maybe it alters the speed sense or something. I'm just saying. It was fine before the install.
Old Mar 20, 2010 | 01:57 AM
dmroberson's Avatar
dmroberson
Gonna take it out tomorrow... Still having trouble starting, and getting a Service Engine Soon light. Says it's a Crank Position Sensor A circuit malfunction... and takes 2 long starts before it turns over.
Old Mar 20, 2010 | 04:56 PM
dmroberson's Avatar
dmroberson
Ok. The unichip is out. Steering has returned to normal. No CEL anymore and starts up easily, like it used to. Emailed unichip and am waiting to see what they say
Old Mar 20, 2010 | 05:04 PM
240tog35's Avatar
240tog35
You got a F#@Ked up Unichip...
Old Mar 20, 2010 | 06:20 PM
dmroberson's Avatar
dmroberson
I'm curious though, there was a long gray cord coming out of the unichip that I couldn't figure out. The install instructions didn't say where to plug this in... Maybe it has something to do with the problems I'm having?
Old Mar 21, 2010 | 05:00 AM
KingBaby's Avatar
KingBaby
Hardest Setting
man I'll say in all return, and don't use again...
Old Mar 21, 2010 | 05:45 PM
dmroberson's Avatar
dmroberson
Well, I just found out that a cord that wasn't described in the install instructions, is supposed to connect to the crank position sensor. Could be the source of my problems. Will investigate this a little further...
Old Mar 21, 2010 | 06:03 PM
binder's Avatar
binder
that will fix your cranking problems.
the ecu has nothing to do with the steering. steering is always harder when the car isn't moving due to the friction of static tires verses moving tires.
Old Mar 21, 2010 | 11:34 PM
dmroberson's Avatar
dmroberson
Just gotta figure out the easiest way to run this wire from where the ECU is, to under the car, where the sensor is...
Old Mar 25, 2010 | 10:08 PM
dmroberson's Avatar
dmroberson
Ok, I took another stab at installing the unichip today. Actually figured out how to run the wire into the engine bay a few days ago. Anyway, connected it to the crank sensor, and the car runs perfectly again.
Old Mar 25, 2010 | 10:57 PM
Waiz's Avatar
Waiz
This certainly has been educational.
Thanks for sharing
Old Mar 26, 2010 | 02:15 AM
dmroberson's Avatar
dmroberson
Are you being facetious, waizzz? lol. I think the only thing it shows is how much of a 'tard I can be at times...
Old Mar 26, 2010 | 06:47 AM
binder's Avatar
binder
good to hear. it's always good when it's a simple problem
Old Mar 26, 2010 | 09:56 PM
dmroberson's Avatar
dmroberson
So far, it seems that my idle is smoother, and the car feels like it pulls harder, when I'm on it...
ginobetterfly
Jul 31, 2007 04:31 PM
ginobetterfly
Jul 31, 2007 02:27 AM
MustGoFastR
Nov 29, 2006 05:21 PM
ANXIOUZ
Southern California
May 16, 2006 02:17 PM
jkoc
Jun 4, 2005 07:24 AM
