haltech: cold and hot start issues
Old Jan 13, 2011 | 08:05 PM
deanfootlong's Avatar
deanfootlong
i will check as soon as i can find a haltech software that i can download on to my new laptop that does not have an error after i download and install it. the one off hals website will not open for me on any of three computers that ive tried it on.
Old Jan 14, 2011 | 05:37 AM
str8dum1's Avatar
str8dum1
get it straight from haltech website then
Old Jan 14, 2011 | 07:10 AM
deanfootlong
will do. currently at work. i'll be messing with it this weekend. i'll update when i do so.
Old Jan 14, 2011 | 05:40 PM
deanfootlong
Originally Posted by BlinkerFluid
What is the cranking ignition timing set at? It sounds like it may be too high.
ok. crank ignition timing is set at 8.0 at both 0 and 399 rpms. thoughts?
Old Jan 19, 2011 | 05:40 AM
deanfootlong
anybody think my cranking problem could be my crank angle sensor intermittently going out?
Old Jan 19, 2011 | 06:52 AM
str8dum1's Avatar
str8dum1
if you miss counter, continues to get hits after the car starts, then your crank sensor might be bad. if it stays at 0 or 1, then there is nothing wrong with it.
Its a magnetic switch, so it would tough for it to just work intermittently.
Old Jan 19, 2011 | 07:19 AM
deanfootlong
good point. i'll change my datalog to record once i flip the key and log miss counter. problem is, its so random that it more than likely wont happen when im trying for it. but its worth a shot.
Old Jan 23, 2011 | 02:44 AM
wannabuy350z's Avatar
wannabuy350z
depending your type of injectors and size. but i have tuned cars upwards of 13-15 both cells of course
Old Jan 23, 2011 | 04:48 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Quite possible. The first place I see trouble from crank/cam sensors is during cranking.
The problem you are describing sounds more like cranking ignition timing and/or fueling related.
Old Jan 24, 2011 | 03:45 PM
deanfootlong
heres a quick look at some of my configurations. to give you an idea, my fuel set up is simple. walbro 255, dw 600's, return system. hal, can you take a peek at this and see if anything unusual catches your eye?
mixplot.jpg?t=1295916226
Old Feb 1, 2011 | 09:31 AM
rcdash's Avatar
rcdash
What is your idle IPW (the fuel injector msec read out when the car is idling)? My post start enrichment at 0 and 1 secs is set to like 100% in cold weather. Maybe 50% in hot weather. 15% is nothing. I have no trouble starting at all with these values.
Old Feb 1, 2011 | 11:04 AM
deanfootlong
i will take another look at my map. i could post that up too for you to take a look at. this morning i had a problem with post start enrichment. so i'll increase those values a lot and that will fix it. still having problems with cranking and getting it to turn over tho. crank crank tick/stop problem still exists.
Old Feb 2, 2011 | 05:40 AM
deanfootlong
well its not that i have a problem STARTING. its just that i have a problem getting it to turn over. i messed with my crank ignition timing by adding 6 percent, nothing. but i did change my post start enrichment by adding about 20 percent. this morning i didnt have any problems keeping it running properly. but i did have problems getting it cranked over. crank crank tick/stop crank crank start.
Old Feb 12, 2011 | 10:22 AM
rcdash's Avatar
rcdash
Sounds like a dead battery or starter.
Old Feb 12, 2011 | 05:30 PM
binder's Avatar
binder
yep, fuel has nothing to do with the engine not being able to physically turn over.
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
