Uprev Ignition Timing Chart
Old Jun 28, 2013 | 11:23 PM
Z-speed33's Avatar
Z-speed33
Default Uprev Ignition Timing Chart
Hello everyone,
I have recently built the bottom end of my 2004 350z to handle some boost. I am using uprev software to tune it. While attempting to tune, went into the ignition timing tab and found a chart of numbers that is basically useless to me. Is there any type of conversion chart to change these numbers to degree of crank revolution, or can anyone make any sense of these numbers to me.
I will try post a picture of the chart tomorrow, as I can't open the rom editor while not connected to the ecu and I have the car at the shop still.
Thanks.
Old Jun 29, 2013 | 04:32 AM
djamps's Avatar
djamps
No direct conversion, but you can read the manual to learn what 'burn time' means.
Old Jun 29, 2013 | 07:57 AM
Z-speed33's Avatar
Z-speed33
Where do I get the manual. I checked the documents section on their site and didnt see it there. I didn't get it in the box. Is there a pdf of it somewhere?
Old Jun 29, 2013 | 08:03 AM
Unbootable's Avatar
Unbootable
Thanks.
Please do, I've been desperately looking for the OEM ignition timing table .
Thanks,
Old Jun 29, 2013 | 12:27 PM
str8dum1's Avatar
str8dum1
he's just going to post the burn time table that uprev uses, there is no ign timing table in crank degrees
Old Jun 29, 2013 | 05:37 PM
Z-speed33's Avatar
Z-speed33
My chart doesn't say burn time. its time for max cylinder pressure. So there is no way to convert this, nobody knows where I can get the manual that describes how this works?
Old Jun 30, 2013 | 02:19 AM
amr_electron's Avatar
amr_electron
UpRev Nissan Tuning Guide .
Old Jun 30, 2013 | 07:14 AM
Unbootable's Avatar
Unbootable
Old Jun 30, 2013 | 08:51 AM
Z-speed33's Avatar
Z-speed33
Thanks for the link amr
Old Jun 30, 2013 | 09:46 AM
djamps's Avatar
djamps
Burn time == time for max cyl. pressure... again, read the manual. Three times is best.
Old Jul 1, 2013 | 12:44 AM
Z-speed33's Avatar
Z-speed33
read the manual, and was using the rom edittor and real time tuning all at the same time and worked out really well. now just gotta work out some mechanical kinks and get my boost to 18psi =)
Obadabot
Jun 18, 2023 11:31 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
