It's Official:NISMO Dual Cold Air Intake for the VQ35HR!
Old Oct 25, 2007 | 12:23 PM
  #121
T_K's Avatar
T_K
Anyone else think it looks like a rebadged AEM?
TK
Old Oct 25, 2007 | 12:24 PM
  #123
itsjiggajames's Avatar
itsjiggajames
Originally Posted by SOLO-350Z
My guess would be yes but barely. Looking at the height of the composite radiator support and where it meets the engine, it doesn't look like it's higher than the engine cover itself, and it goes down to where it's at the top of the radiator support.
The two ideas I have if it doesn't work, would either modify the shield with a cut in it around the bar, OR, the better way would be to get some washers and lift the center part of the bar that has two bolts on each end up like we do with the strut bar to give it a little more room. This should still clear the hood as well.
But IMHO I think it will clear.
It's probally a tight fit. When we were installing yesterday, everything was a tight fit and not exactly 100% flush.. got to kind of move it around. As for the headshield fitting under your nismo strut bars, I think a better solution would be to trim 1/2inch off the top of both heatshields and then insert the rubber seal thing on top.. (if it does not fit.) U can kind of bend the heatshield to make it clear too.. his heatshield came prebent (damaged in shipping?) and we had to kinda bend it back.
Old Oct 25, 2007 | 12:25 PM
  #124
itsjiggajames
TK
could be, it comes with a dry filter element, which i've only seen on AEM filters. But the filter itself is white, sort of OEM like material.. not bad.
Old Oct 25, 2007 | 12:34 PM
  #127
Allen331's Avatar
Allen331
maybe , probally rebadged.
Old Oct 25, 2007 | 12:36 PM
  #128
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Originally Posted by MC
Sadly, it looks identical to a AEM. I bet AEM makes it for NISMO and that is why AEM came out with it first, then NISMO did later because they were waiting for them to come in. Heat shields even look the same.
  #129
itsjiggajames
btw there were suppose to be these foam inserts that were suppose to be added by the exposed sections on the passenger side heatshield to close up that 1 inch gap between the heatshield / bumper. We never had those.. if you guys get those in the box let Allen know.
Old Oct 25, 2007 | 12:40 PM
  #131
Allen331's Avatar
Allen331
Some more clearance pictures for all you Nismo Z owners out there
Old Oct 25, 2007 | 12:41 PM
  #132
Allen331's Avatar
Allen331
**** sorry for the huge pictures.
Old Oct 25, 2007 | 12:47 PM
  #133
mkn's Avatar
mkn
ok am i blind which 1 is the heat shield ? is it right next to the fliter that little black thing ?
Old Oct 25, 2007 | 12:48 PM
  #134
itsjiggajames
they probally are rebadged aems.. they were made in the good ole US of A. btw in those pics that rubber part on top is hollow and very flexible..
Old Oct 25, 2007 | 12:54 PM
  #135
mkn's Avatar
mkn
well to me nismo intakes are ok... i think i would rather wait for ARC intakes unless some 1 wanna spot me 429.99
Old Oct 25, 2007 | 01:06 PM
  #136
quidproquo's Avatar
quidproquo
Need a Tune!!!
I'll do one better for you.... I measured the outside filter measurements and the airbox bracket measurements that the filter must fit into:
OUTSIDE MEASUREMENTS
33 Height in mm
181 length in mm
168 width in mm
INSIDE MEASUREMENTS
27 Height in mm
170 length in mm
157 width in mm
Let us know if you find compatible K&N replacements SOLO... I'm interested in replacing the stock intakes and just dropping K&Ns in.
Someone here who has removed their intakes and has access to the panel filter, can you do me a favor and measure the filter for me? Since our NISMO's have that bar in the way it's way to hard to take off just to measure. I am gonna try to find a suitable replacement that K&N might make close to the stock size.
I need the following below:
Height in mm
Outside length in mm
Outside width in mm
H - Height
A - Outside Length
B - Outside Width
Old Oct 25, 2007 | 01:10 PM
  #137
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
So which is which then? Sorry I am a bit confused.
Old Oct 25, 2007 | 01:15 PM
  #138
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
This one might work!!! What you think?
http://www.knfilters.com/search/prod...x?Prod=33-2258
SUZUKI AERIO 2.0L-I4; 2002
33-2258 Product Specifications
Product Style: Panel Air Filter
Height: 1.313 in (33 mm)
Outside Length: 7.125 in (181 mm)
Outside Width: 6.313 in (160 mm)
Filter Re-Oiling Amount: 0.68 oz (20 ml)
Weight: 0.8 lb (0.4 kg)
Product Box Length: 9.81 in (249 mm)
Product Box Width: 7.69 in (195 mm)
Product Box Height: 1.88 in (48 mm)
Old Oct 25, 2007 | 01:16 PM
  #139
quidproquo's Avatar
quidproquo
Need a Tune!!!
The outside measures the overlap past the filter brackets... The inside is a measurement of the actual filter brackets. If the filter must fits within the brackets, don't you need the inside measurements as well as outside??
Old Oct 25, 2007 | 01:21 PM
  #140
quidproquo's Avatar
quidproquo
Need a Tune!!!
The width is 8mm to short... But it should still overlap the filter bracket (157 vs 160)!!!
