It's Official:NISMO Dual Cold Air Intake for the VQ35HR!
The one I found above is the only one available close to that size. Everything seems to meet your outside spec, so it should fit I think.
I need really the filter not the bracket measurements.
Originally Posted by mlatham
im new here and have not introduced myself properly but i put the nismo CIA's onto my nismo 350 and there is plenty of clearence. millimeters worth, but still plenty.
I went by Oreileys and that drop in K&N is special order and no one in town has it. I had them check for paper filters as well for that vehicle, and they didn't have it in stock either. So I am sol.
damn, from the looks of it, you definitely will need to take off your nismo strut... you already have to take off the a/c line mounts under your driver side airbox to slide the heat shield in, but it also looks like the fitment will be really close.. I don't know about your idea bout installing washers to raise your strut, i think i'd rather cut the heatshield.. one is a structural support the other is just a fancy heat shield. Good luck on the install though. btw that perforated looking line is where the metal starts. Everything above that perforation / stitching is soft hollow rubber made to compress when the hood is closed for a seal..
edit: just read the above nismo owner having nismo cai.. so i guess it will fit, but installing you probally need to take off the strutbar
Guest
Posts: n/a
yeah the nismo strut has to come off for sure for the install. you cant even change a drop in filter without taking it off
That's what I was waiting for.. Time to order it now
Attachment 166183here we go!
Originally Posted by pinoiZ
why paint it?if you can buy a black nismo intake?
He already owned the AEM and decided to paint the them to match the NISMO. No reason to sell it to get a NISMO for the same intake just for color.
