Sputtering During Warm-up
Old Dec 21, 2008 | 09:56 PM
  #321
stylett9's Avatar
stylett9
you have sensor problems, not what we have.
Tac, to understand you right we need to try 5w30 motor oil?
Because i've already tried switching back and forth between motul(not sure which weight) and mobile 1 full synthetic and neither have made a difference. I'm due for an oil change soon so i'll try 5w30 if thats what you are saying.
Old Dec 22, 2008 | 12:21 AM
  #322
gennosuke1's Avatar
gennosuke1
that gives me a bit of relief... so its because of the sensor the rpm goes up when its cold?
Old Dec 22, 2008 | 12:49 PM
  #323
Tac-M's Avatar
Tac-M
yes. i don't know how to explain this, but if you can try mobil1 5w30 or motul 5w30 with OEM oil filter and let us know, that would be very cool. If I am right, within 2-3 runs to the grocery store, the problem will go away.
I believe it has to do with the valvetrain operation.
Old Dec 22, 2008 | 11:54 PM
  #324
stylett9's Avatar
stylett9
alright, not sure when i'm ganna have a chance to do my oil change but i'll keep the thread updated when i do.
Old Dec 22, 2008 | 11:57 PM
  #325
stylett9's Avatar
stylett9
Honestly i didn't read your post too detailed but i'm almost positive what you are experiancing is not what the rest of us had.
Your problem sounds very similar to when i had o2 sensor issues when i installed HFC's.
I would have a check engine light due to one of my o2 sensors in my header( theory is that it was damaged by the impact wrench) and when i would accelerate to 2700 RPM, the car would stutter for a little bit, then keep accelerating as if everything is normal. Replaced the o2 sensor and completely fixed the issue.
I would take your car into a dealer and have then run the code on your CEL. If in fact it's an o2 sensor or any kind of sensor, replace it and i'd bet money it will fix your issue.
Old Jan 5, 2009 | 12:29 AM
  #326
gennosuke1's Avatar
gennosuke1
i just got back from my trip and this is the first thing i remembered thanks i will get sensors or non foulers but i dont wanna take it into dealer because they will see i have test pipes. im pretty sure the light is on because of this will let you know what happens.
thanks
Old Jan 10, 2009 | 08:43 AM
  #327
stylett9's Avatar
stylett9
tried the oil change. Motul 5w30 and no change. I guess it's up to a reflash now...
Old Jan 10, 2009 | 11:21 AM
  #328
Tac-M's Avatar
Tac-M
did you have a chance to drive around for a few days?
Old Jan 13, 2009 | 05:02 PM
  #329
stylett9's Avatar
stylett9
been driving it for about a week now with no change. Also i didn't realize it, but the motul oil i've always been using was 5w30. Standard oil change for Z's at West Covina Nissan. :-(
Not sure if i want to fork out 600 bucks for a reflash.
Tac-M, you said you did your reflash with a hand held device that you get to keep? Is it possible for me to pay you to borrow yours to give it a try? or is it something that is permanently connected to your car?
Old Jan 13, 2009 | 06:02 PM
  #330
Tac-M's Avatar
Tac-M
was it 300v 5w30 ?
anyway, i have no idea anymore...... it is not the flash. and i don't think you should pay 600 to try it. and unfortunately cobb made it impossible to "share " the device. it locks on the the ecu.......
Old Jan 14, 2009 | 10:16 AM
  #331
Pokémon's Avatar
Pokémon
Michael,
If you want to try my Cobb AP, you can. I just have to uninstall mine, and install it in yours.
Old Jan 15, 2009 | 09:45 AM
  #332
j.arnaldo's Avatar
j.arnaldo
I use 5W30 "MOBIL 1/12,000-mile" synth' oil, but I change it every 6,000 to 7,500 miles, just to be on the safe side. So far, so good. It pours out amber-colored (cleaner than the old dino oil used to come out after just 3,000 miles!). NO PROBLEMO. At any rate, I don't think the sputtering has
anything to do with motor oil; it's pro'bly fuel injector(s), electrical or some other kinda problem.
Old Jan 16, 2009 | 07:36 AM
  #333
Tac-M's Avatar
Tac-M
that is the only relevant statement.
Old Jan 20, 2009 | 08:57 AM
  #334
stylett9's Avatar
stylett9
was it 300v 5w30 ?
I believe it is 300v 5w30.
Do you still have the issue or is it still gone with your reflash?
Old Jan 20, 2009 | 08:59 AM
  #335
stylett9's Avatar
stylett9
Originally Posted by Pokémon
Michael,
Hey Larry that's really cool of you. I'll hold off for now but i'll keep it in mind. How hard is it to install and uninstall? Is it plug and play or did you have to splice wires?
Old Jan 20, 2009 | 10:21 AM
  #336
Tac-M's Avatar
Tac-M
^ cobb is a total plug and play. 15 min to flash the ecu. and make sure you say " yes" to save the oem specs for uninstall.
Old Jan 20, 2009 | 12:02 PM
  #337
Pokémon's Avatar
Pokémon
It's like a mini OBD scanner that flashes your ECU. If you have the time; stop by it shouldn't take no longer than an hour.
Old Jan 20, 2009 | 01:44 PM
  #338
stylett9's Avatar
stylett9
are you still "sputtering"?
Old Jan 20, 2009 | 05:03 PM
  #339
Tac-M's Avatar
Tac-M
no.
here are the 3 things that i have done.
1. cobb ap - Stage 2+
2. from 10w40 to 5w30 same 300v
3. oil catch can.
EDIT:
Some other stuff:
1. Bypassed throttle body heater loop
2. HFC and full Y-Pipe Catback
3. FAKE EVAP Canister - that was AMUSEing
4. Injen Intakes
5. 3 more ground points one fat one from the Negative and 2 to TBs
That's about it.
Old Jan 20, 2009 | 09:09 PM
  #340
stylett9's Avatar
stylett9
damn your car is sexy. Despite all those mods though, you said it went away after your reflash correct?
