Berk Metalic HFC and CEL
Old Apr 30, 2008 | 05:50 AM
WalkerT's Avatar
WalkerT
Professional
Default Berk Metalic HFC and CEL
Well yesterday I got 0430 CEL light and reset it. Drove fine all last night. Then this morning on the way to work 0430 again.
Anyone dealing with this? Should it put steel wool in the bung for the O2?
Old Apr 30, 2008 | 06:17 AM
Tac-M's Avatar
Tac-M
that sux... i have the same setup, but so far so good
Old Apr 30, 2008 | 09:12 AM
Allen331's Avatar
Allen331
Hm..that's odd. This is my second time around with this setup, and no problems yet. What is that code exactly?
Old Apr 30, 2008 | 09:50 AM
350Zimo's Avatar
350Zimo
how long have you had them? cant you write a complaint to Berk and have them take care for the issues?
Old Apr 30, 2008 | 10:09 AM
07JimmyZ's Avatar
07JimmyZ
I had the 0430 code about 3 weeks ago for the first time. had my buddy scan it and cleared it and nothing since
Old Apr 30, 2008 | 10:16 AM
Nexx's Avatar
Nexx
guess its time to try some non foulers, Travis.
Old Apr 30, 2008 | 11:01 AM
itsjiggajames's Avatar
itsjiggajames
Wierd.. contact berk see what they say. I've had this setup for 7k miles now, not a single light.
Old Apr 30, 2008 | 11:11 AM
WalkerT's Avatar
WalkerT
Professional
I had mine for 3000 and a lot of racing.
Code is for #2 bank O2
I rest them my self but it came back.I reset it again and I am sure it is only a matter of time till it comes back.
The berks have built in non foulers.
Old Apr 30, 2008 | 11:21 AM
warmmilk's Avatar
warmmilk
maybe the o2 got damaged during the install???
Old Apr 30, 2008 | 11:59 AM
WalkerT's Avatar
WalkerT
Professional
Wouldn't that have show up three months ago?
I think if it happens again then I am going to put the stock ones back on for awhile and see if it comes back.
Old Apr 30, 2008 | 12:02 PM
WalkerT's Avatar
WalkerT
Professional
Or I could swap the O2 sensors from left to right.
Old Apr 30, 2008 | 12:03 PM
Nexx's Avatar
Nexx
thats strange, hfc's and they have non foulers installed? maybe a leak?
Old Apr 30, 2008 | 01:07 PM
itsjiggajames
I'm willing to bet it's a damaged 02 sensor.. some members on the forums had the CEL light pop up and took it in and indeed it was the 02 sensor.
Old Apr 30, 2008 | 01:38 PM
WalkerT's Avatar
WalkerT
Professional
Well then I will swap the sensors from left to right.
Metalic hfc are not like ceramic. The metalic hfc's act like test pipes until they reach a high temp. That is why they have nonfoulers welded on them.
Old Apr 30, 2008 | 02:14 PM
itsjiggajames
And I don't think they have rhodium or platinum in them either, so yea they aren't that much better than test pipes at not polluting. better, but not much..
BTW do you recall taking the sensors out before you tried using an impact wrench to take off your bolts when installing? The impact wrench can mess up the 02 sensors from the hard vibrations. Hard to believe, but that's the truth.. I took mine out before the gun hit the bolts. no problem so far.
Old Apr 30, 2008 | 07:03 PM
Buddy Revell's Avatar
Buddy Revell
Sorry for the noob question, but what are the o2 sensors for? There's one on each header right before the cat and one after each cat, correct? Do they affect a/fuel ratio at all or how the engine runs in some way, or are they only there for emissions purposes?
edit: The guys at Technosquare told me that the o2 sensors right before the cat are a little more important than the ones after the cat and are like a secondary system that measures air/fuel ratio, the MAF being the primary system (at least I think that's what they said, haha).
Old Apr 30, 2008 | 07:28 PM
blazefast's Avatar
blazefast
I know when I had my Prelude, the primary O2 sensor (before cat) did have an effect on performance, fuel maps, etc. The secondary O2 was there purely for emissions purposes. I'm assuming things are the same for the Z
Old Apr 30, 2008 | 08:38 PM
Allen331's Avatar
Allen331
Hey Travis, I think they are your 02 sensors. I recall one member having his HFC installed, and his o2 sensor failed on him a few months down the line. It might've gotten a tad bit damaged when you installed them, and slowly went to chit from there.
Old May 1, 2008 | 04:51 AM
WalkerT's Avatar
WalkerT
Professional
Yea I will do some touble shooting this weekend looking at voltage and swaping them around to see if the code changes to bank #1. I will let you guys know how it goes. I was extra carfull when removing and installing them.
Old May 4, 2008 | 05:18 AM
WalkerT's Avatar
WalkerT
Professional
Well I swapped over the O2 sensors from left to right. I also checked the voltage and it is reading correct.
I am also driving the car alittle different. Before I would do a WOT run to get on the highway with in 10 minutes of starting up (highway I take to work is with in ten minutes of the house) and I would get the code shortly after. SO now I wait until 15+ minutes has past before WOT. My thinking is if I let the Metalic reach the right temp before I WOT then the ecu will see the right reading. I have done this three times sense yesterday and no codes. I will update later this week.
