Installed FI high flow cats yesterday
Old Jul 28, 2008 | 07:21 PM
kramykram's Avatar
kramykram
Originally Posted by evil_tt
Hows the rasp? Bad if any?
its a differnt tone on the hi flows than it was on my test pipes. to me it does not sound raspy. to others it might idk i just like the way it sounds.
kramykram's Avatar
kramykram
Originally Posted by itsjiggajames
Socal here with berk HFCs. I've had these for roughly 9k miles w/ no issues.. no light what so ever.
yes but are you running metalic or ceramic?
Old Jul 28, 2008 | 07:38 PM
infinite's Avatar
infinite
How long have you had them installed? Does it come with non-foulers?
Old Jul 28, 2008 | 07:45 PM
infinite's Avatar
infinite
I wanted to get a metal substrate, but I've read about too many CEL issues, I figured ceramic will be the way to go. I'd hate to have my car smelling like bad exhaust and having issues passing CARB smog checks.
Old Jul 28, 2008 | 08:30 PM
kramykram's Avatar
kramykram
thats the joy of living in mississippi.
Old Jul 28, 2008 | 08:50 PM
singh's Avatar
singh
_______________
itsjiggajames is running metallic cores like me. I have had mine for about 2,000 miles now. Zero issues.
The Berk cats do have built-in non-foulers. Check out my picture:
Old Jul 28, 2008 | 09:15 PM
kramykram's Avatar
kramykram
nice so im sure that putting in the non foulers will give me the same results as you as listed above.
Old Jul 28, 2008 | 09:16 PM
infinite's Avatar
infinite
I don't get why the wideband bung is after the cat instead of before it
Old Jul 29, 2008 | 07:10 PM
quidproquo's Avatar
quidproquo
Need a Tune!!!
I never had a bad smell with the metallic cats... Even when the CEL was coming on (that's why I opted not to go with test pipes).
Smells as clean as OEM.
Old Jul 31, 2008 | 02:09 PM
itsjiggajames's Avatar
itsjiggajames
metallic cats.. slight rasp when cold.. maybe lasts 2-3 mins? change your OEM gaskets to NISMO gaskets if you are using nismo exhaust. Reduces rasp. I've had these on since beginning of 08. January I believe. Next up, motordyne XYZ pipe. No more rasp w/ that built in resonator on that xyz pipe. I believe at that point I will have pure audible bliss..
Old Jul 31, 2008 | 02:18 PM
singh's Avatar
singh
_______________
+1 on the MD XYZ pipe. I'm right behind you!
I want to hear some sound clips though w/ and w/o that built-in resonator. ginobutterfly and Tony @ MD said they will post sound clips of both setups.
Old Jul 31, 2008 | 03:27 PM
kramykram's Avatar
kramykram
+2 can't wait myself.
Old Aug 5, 2008 | 11:30 AM
kramykram's Avatar
kramykram
bah non foulers in and getting p2ao3 and p2a00. i was very gentle with my sensors when i took them out so i doubt i have damaged them. i really don't feel like buying 2 new ones to find out they are not bad.
Old Aug 5, 2008 | 04:24 PM
quidproquo's Avatar
quidproquo
Need a Tune!!!
Wait... Those aren't the codes I was getting before installing my non-foulers.
I was getting these:
P0420: Catalyst System Efficiency Below Threshold (Bank 1)
P0430: Catalyst System Efficiency Below Threshold (Bank 2)
You're getting these:
P2A00 O2 Sensor Circuit Range/Performance (Bank1 Sensor1)
P2A03 O2 Sensor Circuit Range/Performance (Bank2 Sensor1)
Not sure what's causing yours...
Did you check for exhaust leaks around the HFCs? When I installed my FI HFCs, I was getting a leak because the new ring gaskets supplied by FI weren't seating properly causing them not to crush as intended. I spoke to Tony from FI and he suggested I reuse the gaskets that came with the OEM CATs. That solved my leak.
Old Aug 5, 2008 | 11:20 PM
kramykram's Avatar
kramykram
i talked to tony also, he told me to use high temp silicone and i haven't had a leak since. he said he is in the process of getting a gasket made just for the hi flows but for now the high temp will have to do.
Old Aug 6, 2008 | 03:12 PM
kramykram's Avatar
kramykram
ok just ordered some berk tech copper gaskets. so if i have a leak i hope it will be gone after that
AbrasiveRaysive
Sep 20, 2021 02:29 PM
