Bogging - stock car.
Old Dec 3, 2008 | 06:28 AM
Emerald99's Avatar
Emerald99
Default Bogging - stock car.
I bought my Z w/ 12,000 on it a few months ago. I'm at 18,000 right now, and the car started bogging/hesitating today at seemingly random RPM ranges.
It happened down low, gave it gas, no revs, then all of a sudden it'd 'catch' and move forward. Happened in the mid-range, and I didn't push it up high. I don't have any CELs yet, but I am very confused. Any ideas as to what it could be?
Old Dec 3, 2008 | 06:36 AM
kacz07's Avatar
kacz07
clutch
air filter is dirty
MAF sensor unplugged
Old Dec 3, 2008 | 06:48 AM
Emerald99's Avatar
Emerald99
I was thinking clutch as well- but would that really be a cause of hesitation? During the .5-1.5 seconds of hesitation, the engine doesn't rev any higher, even if I floor it. If it were a clutch issue, it would rev, but not go anywhere- right?
Old Dec 3, 2008 | 07:23 AM
kramykram's Avatar
kramykram
if its under warranty i would take it to dealer ship. but check airfilters first.
Old Dec 3, 2008 | 09:06 AM
350z 6spd's Avatar
350z 6spd
Could be a dirty maf sensor. I'd buy a can of maf cleaner and see if that works. (and you can use the maf cleaner to clean other parts if it doesn't work lol)
Old Dec 3, 2008 | 10:13 AM
stinky350z's Avatar
stinky350z
Where do u get a maf cleaner thank u
Old Dec 3, 2008 | 10:18 AM
Emerald99's Avatar
Emerald99
So I have an appointment scheduled with Passport Nissan (Alexandria for the mid-A guys) for 11 AM tomorrow. I have a feeling the car is going to be perfectly fine, and that they won't be able to reproduce any problems, which is always how crap like this works, lol. So I'll run through the checklist tomorrow. So far I have:
Air Filters
MAF Sensor Unplugged / Clean it
Check fluid levels
Compression Test
Clutch
Last Resort:
Do TPS and idle air relearn procedure as specified in the FSM
throttle body reset procedure
And, where is the MAF sensor located? And how exactly do I clean a sensor without damaging it?
Thanks
Old Dec 4, 2008 | 11:35 AM
350z 6spd's Avatar
350z 6spd
Auto parts store. The stuff I have is made by CRC.
Old Dec 4, 2008 | 11:36 AM
OldDirty Z33's Avatar
OldDirty Z33
reset ecu! unplug the negative for 5 mins
Old Dec 4, 2008 | 11:38 AM
350z 6spd's Avatar
350z 6spd
Air Filters
Check fluid levels
Compression Test
Clutch
Last Resort:
Thanks
There are 2 maf sensors on the hr motor. They are located in the intake tubes behind the air filter housing. Unscrew them and spray them with mass air flow sensor (maf) cleaner.
Old Dec 4, 2008 | 11:39 AM
OldDirty Z33
doubt thats the problem
Old Dec 4, 2008 | 11:42 AM
350z 6spd's Avatar
350z 6spd
You may be right but why not try it?
Old Dec 4, 2008 | 11:45 AM
OldDirty Z33
true.
Old Dec 4, 2008 | 11:46 AM
OldDirty Z33
If anything sounds like a fuel problem.
Old Dec 4, 2008 | 12:45 PM
AKITO_25's Avatar
AKITO_25
Bro I had something like that happen to me recently, I got lost W/O gas went to Hess (I know, I know) car did that till I went thru the tank, den it ran fine after Shell gas, hope you get it fixed. Regards.
May 30, 2017 03:28 PM
Mattg350z
Oct 2, 2015 06:51 AM
