VQ35HR Intake Manifold
Old Jan 17, 2016 | 08:30 AM
  #101
John_B's Avatar
John_B
Originally Posted by cincysilvias14
i havent seen anything dyno wise yet, apparently they're going to start work on a hr intake as well
This should fit the HR. You would need the VHR lower manifold and VHR fuel rail.
Old Feb 26, 2016 | 08:39 AM
  #102
John_B's Avatar
John_B
First piece headed to dyno, really looking forward to the results.
Old Feb 26, 2016 | 11:19 AM
  #103
MM'08_350Z's Avatar
I like that RJM lower plenum but it's just too dam expensive!!!!!
Old Feb 26, 2016 | 12:21 PM
  #104
nizmo_0385's Avatar
nizmo_0385
And probably not many gains but please make me eat my words
Old Feb 26, 2016 | 03:42 PM
  #105
MM'08_350Z's Avatar
I was going to pull the trigger on this Lower plenum, but when the guy said $1600 I was like this guy thinks I'm stupid or something. I just told him straight up its too expensive!! He didn't really like my comment and he started trying to make fun of me because I told him I was going to try to make one myself then. He said " I'm going to keep one here next to me for when you give up trying you can call is buy it...." Freaking Jerk!
Old Feb 26, 2016 | 03:46 PM
  #106
HRMoneyPit's Avatar
HRMoneyPit
Yeah that's why they won't be selling many. Horrible business ethics. And lastly 1600 and it doesn't even include half the stuff you need like the manifold and so on. For that much it would need to be making a lot of power which I'm sure it doesn't. It's basically an adapter for a different mani
Old Feb 26, 2016 | 04:37 PM
  #107
MM'08_350Z's Avatar
Exactly!!! It's just an adapter, he started going off on me saying that they spent I dont how many thousands of dollars for he 3D scanning and the 3 engineers that worked in developing the adapter. I think they just want their investment back real quick! That's just not the way to do business! 👎🏼
Old Feb 26, 2016 | 04:42 PM
  #108
nizmo_0385's Avatar
nizmo_0385
Damn just an adapter fml. The aam is complete for 2k so yea idk thats still insane.
Old Feb 26, 2016 | 08:13 PM
  #109
HRMoneyPit's Avatar
HRMoneyPit
2k with no power numbers
Old Feb 27, 2016 | 06:06 AM
  #110
Conway_160's Avatar
Conway_160
How much different, is a the Gtr Lower than a HR lower manifold?
Old Feb 27, 2016 | 09:14 AM
  #111
John_B's Avatar
John_B
AAM is not complete, unless I'm missing something. You would need 370z fuel rail and lower intake manifold. Even with that manifold the lower manifold is a huge bottle neck. RJM solution basically improved more air flow in comparison to stock. 1880+fuel rail+lower manifold it will be close to the RJM with GTR manifold.
Old Feb 27, 2016 | 04:30 PM
  #112
MM'08_350Z's Avatar
A GTR lower sits on a flat surface and VQHR/VHR sit on 45 degree angles.
Old Mar 6, 2016 | 09:48 AM
  #113
Juztin's Avatar
Juztin
Start an open source movement to create a HR adapter for the full GTR plenum stack. 3D print and try until the adapter is dialed in, then line up a fabber to make the piece off of the 3D object.
/Can't stop the signal Mel
Old Mar 16, 2016 | 05:05 PM
  #114
MM'08_350Z's Avatar
**UPDATE**
Gamma Motors Gave me a call and did right by me!! I finally got my Lower Plenum (GTR Manifold conversion)
I test fitted it that same night, literally dropped right in....
I tried putting th manifold on but ver small Fitment issues emerged... 2 tabs that I'm pretty sure that hold the injector harness hit
And the breather tube on the drivers side above the motor oil cap also hit. So I got to cutting with the dremmel...
Result...... Flush AF!!!
Cut tabs I feel I could have gotten away with less but efff it!!
Another thing I am ecstatic about is I can use my OEM motor oil cap!!!
So much room to do activities!!! 😂😂😂
End Result!
Old Mar 16, 2016 | 06:00 PM
  #115
HRMoneyPit's Avatar
HRMoneyPit
Oh Das hot
Old Mar 16, 2016 | 10:22 PM
  #116
cincysilvias14's Avatar
cincysilvias14
**UPDATE**
End Result!
thats beautiful meng.
Old Mar 17, 2016 | 08:09 AM
  #117
Juztin's Avatar
Juztin
Looks good, what kind of fuel rails will work with them? How was the price?
Old Mar 17, 2016 | 10:57 AM
  #118
MM'08_350Z's Avatar
Thanks Juztin, GTM fuel rails and return system which is already installed on my Z and well price was pretty good. Not as bad as RJM..... 😂
Old Mar 23, 2016 | 04:58 AM
  #119
Nismo350z#0310's Avatar
Nismo350z#0310
AAM not complete, but depending on the price, for me it came out the same cost.
The thing about RJM that people need to understand is it can be worth it depending on how high of HP you go, because it allows you to run aftermarket GTR manifolds. Some of those manifolds have top mount secondary fuel rail locations, which you'll need for certain power.
It's not just about power numbers, its about being able to withstand the amount of power people are going for. 370z guy using RJM close deck block and other part hitting 4 digits and the stock manifold blew up on the dyno.
This manifold isnt really for NA cars, but higher 4 digit HP cars.
Depending on how cheap you can get a upper manifold, it will be near the same price as Gamma and possibly less than AAM.
How much did you spend on the GTR upper manifold and cover?
Old Mar 23, 2016 | 05:24 AM
  #120
MM'08_350Z's Avatar
Powdercoated GTR manifold $500, Nismo Ornament cover $250
