VQ35HR Intake Manifold
Old Apr 22, 2016 | 11:36 AM
  #181
phunk2's Avatar
phunk2
Also apparent on the blue run, is that something changed at 4300rpm. The powerbands were identical, and the blue run was climbing in harmony with the red run, and then at 4300 something changed. The blue curve is not tangent at this point.
At this moment, something with the ignition timing or VTC pulled out.
Also shown on the blue run is a momentary drop in engine speed at about 3900rpm. I think its too brief to be clutch slip & catch... so a possible misfire or detonation event? Possibly what provoked the change at 4300 (knock retard)?.
Its hard to tell much from just one graph from each combo, especially without access to the ECU logs.
Old Apr 22, 2016 | 03:13 PM
  #182
Nismo350z#0310's Avatar
Nismo350z#0310
Well, for the thread...
Old Apr 22, 2016 | 04:50 PM
  #183
MM'08_350Z's Avatar
Your right on the money Mr. phunk2, full install took about 2 weeks to fabricate charge pipes and fuel line AN fittings vacuum line ect ect... Then this was the test. I mean 675whp at 18psi wasn't that bad, but I rather 780whp at 18psi... So off it went and on to the Dyno again it is! TOMORROW
Originally Posted by phunk2
That is not A/F, its boost logging.
His tuner put on the GT-R manifold, and began tuning for it, and aborted the mission when he found that the car made much less power at the same boost.
This vehicle owner did not just bolt on the GT-R manifold and attempt to dyno it himself. His tuner had to do the full install which most likely required altering his intercooler pipes and fuel lines and vacuum line setup etc. I doubt at this point they were going to just do a half *** dyno pull and see what happens. This car was already making over 900rwhp originally, they were going to go for the gold.
Old May 10, 2016 | 12:36 PM
  #184
John_B's Avatar
John_B
New results are in for F/I HR Stock internals!
Quoted from Bobby: "Our base was 5 psi at 401 with stock intake and with the GTR it made over 430 and about 40 plus on the torque side and about 1000 rpm sooner. This also means faster spool. We let it cooled down and did another pass at 9psi and made 522"
Old May 11, 2016 | 03:24 AM
  #185
Frankd1210's Avatar
Frankd1210
Default Rjm manifold
Where do I buy it from and does it need to be customized for a twin turbo setup?
Old May 11, 2016 | 04:13 AM
  #186
Nismo350z#0310
Originally Posted by John_B
GTR plenum conversion by RJM Manufacturing on an 08 350Z turbo - YouTube
This is very good news.
Id like to know really high boost numbers , like 25 psi or so
Old May 11, 2016 | 06:50 AM
  #187
MM'08_350Z's Avatar
I am certain this intake plenum @25psi (assuming the motor is fully built...) will only yield between 700-750whp
Old May 11, 2016 | 07:07 AM
  #188
John_B's Avatar
John_B
The motor is stock, so we won't see it anywhere 25psi unfortunately.
Old May 11, 2016 | 07:52 AM
  #189
MM'08_350Z's Avatar
10.6:1 compression stock I believe... So now if they build it and bring down that compression down go the numbers... So more PSI will be need to achieve good numbers.
Old May 11, 2016 | 08:11 AM
  #190
Frankd1210's Avatar
Frankd1210
Default Intake manifold
Damn that sucks. I'm gonna be doing between 800-1,000 whp
Old May 11, 2016 | 08:58 AM
  #191
MM'08_350Z's Avatar
Between 30psi and 40psi.... Kaboom
Old May 11, 2016 | 09:01 AM
  #192
Nismo350z#0310
unless youre like me and do 10.5 CR lol
Old May 11, 2016 | 09:06 AM
  #193
MM'08_350Z's Avatar
Yes sir! I would let go too high though... I'd go 10:1 if I could could do it all over again
Old May 11, 2016 | 09:10 AM
  #194
Nismo350z#0310
strickly e85
little secret, all the alpha GTR builds are 11:1 and Moses 370z build Forge Performance is doing is 11:1
good parts and e85, 11:1 should be fine
Old May 11, 2016 | 09:31 AM
  #195
MM'08_350Z's Avatar
strickly e85
Old May 11, 2016 | 10:31 AM
  #196
Nismo350z#0310
this is top secret info. i may need to take it down haha
and may need to unquote me lol
but now you know
Old May 18, 2016 | 07:27 AM
  #197
Frankd1210's Avatar
Frankd1210
Default Manifold
Where did you find that manifold I seen it on the website but it's not saying much about it?
Everything is coming along great.... Now I need to get rid of that ugly coolant tank.... I hope the GTR Alpha Expansion tank fits...
Old May 19, 2016 | 12:49 AM
  #198
Frankd1210's Avatar
Frankd1210
Where did you buy it from?
Old May 19, 2016 | 07:45 AM
  #199
MM'08_350Z's Avatar
Gamma Motors
Old May 23, 2016 | 11:40 AM
  #200
cincysilvias14's Avatar
cincysilvias14
thing sounds like a damn fighter jet. what turbo is being used?
apex locator
Jul 23, 2021 02:27 AM
