VQ35HR Intake Manifold
Old Apr 1, 2016 | 10:33 PM
  #141
Juztin's Avatar
Juztin
So what GTR conversion kit did you go with MM if not RJM (trying to get a handle on the conversion kits out there haha)? Sounds like JMS did your conversion?
Old Apr 1, 2016 | 11:34 PM
  #142
MM'08_350Z's Avatar
Just bought Gamma Motors Lower plenum and fuel rails that's it, I bought all the other parts on eBay like gaskets and that oil cap. I don't think I spent anything close to $1500.
Old Apr 2, 2016 | 03:20 AM
  #143
cincysilvias14's Avatar
cincysilvias14
im assuming the oem oil cap fits with the gt-r conversion? or is an aftermarket oil cap needed?
Old Apr 2, 2016 | 06:42 AM
  #144
MM'08_350Z's Avatar
Yes the OEM cap fits perfect, but I bought this other oil cap because Racecar
Old Apr 2, 2016 | 07:16 AM
  #145
venture210's Avatar
venture210
I got a better looking oil cap! Don't need it but hey it look bad ***!!
Dam JMS Racing Back At It Again with the bad *** builds!!!
Bolted on!!!! Now to modify and fab new intake pipes
Tell JMS to let me make those charge pipes
Old Apr 2, 2016 | 07:19 AM
  #146
MM'08_350Z's Avatar
I'm not sure if they were going to make new ones or just cut my old ones.
Old Apr 4, 2016 | 11:44 AM
  #147
cincysilvias14
will an ecu reset have to be done after doing this?
Old Apr 6, 2016 | 07:52 AM
  #148
John_B's Avatar
John_B
You will need a tune for this to work.
Old Apr 7, 2016 | 10:31 AM
  #149
MM'08_350Z's Avatar
Everything is coming along great.... Now I need to get rid of that ugly coolant tank.... I hope the GTR Alpha Expansion tank fits...
Old Apr 7, 2016 | 07:07 PM
  #150
John_B's Avatar
John_B
Looking good man!! I'll have the RJM version soon with the big bore TBs.
Old Apr 8, 2016 | 05:02 AM
  #151
Nismo350z#0310's Avatar
Nismo350z#0310
You dont need em. Just run a rubber line to the ground! lol Thats what Im doing
Old Apr 8, 2016 | 06:51 PM
  #152
MM'08_350Z's Avatar
Well People BAD News!!! The car lost power and was actually struggling to make power my tuner went only up to 18 psi and only made 600whp when with the OEM manifold I made 600 WHP at only 10 psi..... I am saddened by this, but now we all know the GTR manifold conversion is only meant for VQ37VHRs
Old Apr 8, 2016 | 07:02 PM
  #153
venture210's Avatar
venture210
I wish I was sad with 600whp
Old Apr 8, 2016 | 07:24 PM
  #154
John_B's Avatar
John_B
No way! I'm sure you need to get it tuned right? There's more volume of air in comparison to stock manifold that needs to be accounted for.
The guy at 370z forum reschedule their dyno for Monday on the RJM version.
Old Apr 8, 2016 | 10:54 PM
  #155
KingBaby's Avatar
KingBaby
Hardest Setting
can't believe that..
looks great tho ! 600 and a great engine bay be happy
Old Apr 19, 2016 | 01:46 PM
  #156
John_B's Avatar
John_B
I was reading the 370z forum and the guy have both GTM and RJM to compare. With the RJM, It sounds like he lost power also w/o any tune and didn't post the results bc of that. The car was running a leaner AFR due to the higher air flow of the manifold. I'm curious how it would affect N/A application.
Old Apr 19, 2016 | 01:56 PM
  #157
phunk2's Avatar
phunk2
Thats just switching his lower intake, as he already had a GT-R upper before. While that is interesting in its own way, he is not going to see a whole lot of difference between the 2 different lower intakes and whatever difference he does see will not help anyone know what to expect when leaving their stock manifold for a GT-R upper regardless of which lower they choose.
MM'08_350Z has just experienced first hand that the GT-R manifold geometry is less ideal over-all. Looks prettier, and will obviously hold up to boost better since its not plastic... but it reduces the efficiency of the engine as a whole. Which is what I have been predicting for years.
So the question is... will MM'08_350Z keep the GT-R manifold on it, or will you go back to a HR or VHR manifold?
Did your car at least pick up some midrange torque from the GT-R conversion? I would have expected to see some mid-range and low-end gains and then some pretty significant top-end losses.
Old Apr 19, 2016 | 06:03 PM
  #158
MM'08_350Z's Avatar
I definitely went back to the OEM plastic manifold, Power over looks for sure
Old Apr 20, 2016 | 04:55 AM
  #159
Nismo350z#0310
Are you sure this is all about the upper???
Could be your kit/turbos/efficiency in combo with the upper??
Old Apr 20, 2016 | 06:11 AM
  #160
Nismo350z#0310
Those types of loses can not be from a GTR upper.
There is something going on whether boost leaks, other inefficiencies, maybe tune wise. I dont see a GTR upper needing 8psi with same numbers. That's wild!!!
BUT, speaking with a former GTM lower user who could have guess it, thing needs to be re-decked, its not even flat, its probably leaking boost, the injectors are at a **** angle, etc etc etc
Who could have guess a GTM product sucked. Been there done that.
