OFFICIAL HR aftermarket clutch thread
Old Jan 19, 2013 | 07:47 PM
blue350zed's Avatar
blue350zed
I've had two on my '07 HR-
1. Exedy Stage-1 for 300+ whp NA build / OS Giken Twin Plate for FI build.
2. A couple thousand miles on each clutch / 16,000 miles on the car.
3. Track days and some street miles. It gets driven hard.
4. Yes. The OEM CSC went out on the track. Had it replaced under warranty.
5. Replaced it with the heavy duty CSC the second time it went out. No issues since.
6. Alot. Stroked and boosted to 650+ whp.
7. No.
Old Jan 19, 2013 | 07:52 PM
ian99rt's Avatar
ian99rt
Originally Posted by J.$
I actually like how low the release point is now and was hoping it would stay how it is, lol. I guess my next mod will be the new RJM bracket because my pedal has developed a clicking noise on the way up.
if you want the engagement point to stay where it is after break in you can modify the pedal like I linked earlier. With your setup (same as mine) you woulnt want what the rjm pedal does, it will allow you to put the engagement point where you want it but needlessly widen the engagement zone. It its better for the overkill clutches that grab so stupid that they can't feather the clutch.
My clutch pedal is like heaven with the zspeed setup and my modified clutch pedal.
Old Jan 20, 2013 | 08:17 AM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Too low of an engagement point is a bad thing, The clutch should be fully release by half pedal. If it is not, you are wearing on the trans syncros every time you shift.. Really, the higher you can get the clutch to release the better it is for your transmission and will allow for the fastest shifts.
May want to check the adjustment rod on the pedal if it is clicking, the nut may be loose on the master cylinder Rod/Clevis.
Old Jan 22, 2013 | 03:23 AM
FastGreg's Avatar
FastGreg
1. What brand clutch and flywheel?
- Nismo Super Coppermix - Twin Plate Clutch
2. How many miles have you had it and how many miles total on your car?
- 5000km for a 60000km car
3. How do you drive it?
-Daily use and tracks
4. Have you had any problems with the CSC?
-Yes
5. Have you done anything to address the CSC, was its preventative or as a result of a failure.
- Yes, change for ZSpeed HD Clutch Hydraulic package CSC and Master Cylinder, and RJM pedal.
6. What other mods do you have / how much power?
- Mine's ECU, Nismo exhaust, sport cats, K&N filters...
7. Comments / anything else you want to add.
I didn't test yet this new package on the track. Thanks to ZSpeed Perf. and RJM to fix the OEM package...
Old Feb 1, 2013 | 10:01 AM
Big Woo's Avatar
Big Woo
Angry
1: Spec stage 3+ clutch and steel flywheel
2: 11,000 mile when clutch and flywheel was replaced, 16,000 currently
3: Spirited
4: Was unhappy with the holding power of the stock clutch, and the differing reactions of the stock dual mass flywheel.
5: No CSC issues since purchasing this vehicle (new purchase)
6: AAM test pipes, Greddy dual exhaust, Tomei cams, AEM intake, Osiris tuner system, oil cooler, Z1 rotors, Hawk brake pads, Z1 brake lines.
7: The ring gear on the Spec steel flywheel failed after about 800 miles, replaced with a light weight Z1 flywheel which has worked great for the last 5200 miles.
After switching to the Z1 flywheel I have been very happy with the Spec clutch and Z1 flywheel combo.
Old Feb 2, 2013 | 03:37 AM
DR Z's Avatar
DR Z
os giken twin disk
car 82000 os giken clutch from 64000
track days / street
yep. after 2 weeks
clutch too "strong". replaced with conceptzperformance csc
450 hp gtm supercharger kit / uprev / oil cooler / injen ses / stillen cat (empty) / tein / advan rs blablabla
350z82
Oct 1, 2015 06:25 PM
