Please Help!!! TECH Help
Old May 16, 2010 | 08:25 AM
MM'08_350Z's Avatar
Default Please Help!!! TECH Help
I changed my air filters to my Injen dual intakes and had problems putting in the passenger side filtration due to the Factory oil cooler so some of the fins got bent. After the filter install I started drving and hesitated in the begining of the first three gears. I stared diving normal and noticed the Oil pressure gauge going all they way up to 120 psi I need to know what the normal operating pressure is. I chaecked the hoses going to and from the oil cooler and no pinches what so ever.
Old May 16, 2010 | 10:50 AM
bottlefedZ's Avatar
bottlefedZ
It could be your sendint unit.You can check it by putting the key foward,it should read zero.If it marks anything above zero it's your sending unit.
Cold Start 120 psi
Cruising 60 psi
Idle 30 psi
Hpoe this helps..........
Old May 16, 2010 | 11:40 AM
Manjot's Avatar
Manjot
do you still have the factory horn brackets? Can I buy them off you?
Old May 16, 2010 | 11:56 AM
MM'08_350Z's Avatar
Ok I already put the key foward and stayed at zero turned it on cold went up to 120 started warming up and went all the way to about 40psi at idle. I would rev it a bit to about 3K and I would leave the RPM @ 3K and goes past 120psi.
Old May 16, 2010 | 01:12 PM
tight350z's Avatar
tight350z
take it to nissan if its still under warranty and have them make sure everythings good man..
Old May 16, 2010 | 04:40 PM
The filters have nothing to do with oil pressure.
Old May 16, 2010 | 08:35 PM
drivessidewayz's Avatar
drivessidewayz
Bending a couple fins wouldn't cause oil pressure to skyrocket. I dunno what it is in an HR but my rev-up is cut off at 90. Are you sure that the fins(of the oil cooler I am assuming) were all you damaged?
Old May 16, 2010 | 09:35 PM
midz350's Avatar
midz350
You mean the steering wheel oil cooler!!
Old May 17, 2010 | 09:27 AM
MM'08_350Z's Avatar
I meant the oil cooler in front of the radiator. A Nissan tech already said he wanted to replace the sending unit to see if that's gonna be the problem. And not all the oil cooler's fins are damaged it's only the top right corner fins.
Old May 17, 2010 | 09:40 AM
redline06's Avatar
redline06
i dont think we have a stock oil cooler with fins, we do have a power steering fluid cooler which is in front of the radiator on the passenger side, and u can bend fins back. u prob installed the intake wrong if its hesitating, check the couplers on the TB
Old Jun 30, 2010 | 12:38 AM
aleeex1's Avatar
aleeex1
Did you ever find out the problem?
Old Jun 30, 2010 | 10:15 AM
MM'08_350Z's Avatar
I haven't... I still have that problem and when I turn on the car let it warm up for around 7-10 minuites oil pressure still goes high and you could even hear and feel to car stutters a lot for like to first 10 minuites oc driving then to oil pressure goes back to nomal. I'm super confused!!!
Old Jun 30, 2010 | 02:47 PM
Lakeside's Avatar
Lakeside
Did they replace the sending unit? Is the car still under warranty? I would push this issue and get it resolved before the warranty ends!
Also a good tuner maybe able to resolve the issue!!! See if there is an UPREV dealer in you area! They notice the issue right away.
Zim
Old Jun 30, 2010 | 03:06 PM
MM'08_350Z's Avatar
Zim
No the sending unit was not replaced and he car is still under warranty with only 11,000 miles on it. The closest UPrev dealer is 6-7 hours away in Austin TX. which I've been there like last year and have done a couple of more mods after the tune. So maybe I do need to take another trip back to Austin for a retune.
Old Jun 30, 2010 | 05:32 PM
aleeex1's Avatar
aleeex1
Same problem started showing up couple days ago. Didn't notice any power loss. Taking it to the dealership tomorrow., keep you updatated
aarrgghh
May 1, 2022 11:04 AM
Workshop12
Mar 23, 2020 01:45 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
