STILLEN Engine Damper Brace For VQ35HR
Old Feb 21, 2013 | 05:49 PM
AURMEND's Avatar
AURMEND
Default STILLEN Engine Damper Brace For VQ35HR
Hi everyone. I need some help. i have lost the mounting bracket. Does anyone know where i can get one online?
If not can someone give me the dimensions so i can create a CAD image file and try to make it myself?
i didnt know where to post this but it is for the VQ35HR.
I have searched. I have emailed STILLEN three times and have not responded. I dont want to buy it again.
It came with the car uninstalled and i lost the piece.
STILLEN Engine Damper Brace instructions
thanks guys,
Old Feb 21, 2013 | 11:20 PM
cata_mahu's Avatar
cata_mahu
You don't especially need the specific dimensions and a CAD drawing... If you can't find them take some carton boards, glue, scissors and make yourself a model to fit where you want. Then you replicate it from metal. You take it little by little, cut, try in position, adjust again etc until it fits properly. Hope it helps.
Old Feb 22, 2013 | 09:27 AM
AURMEND's Avatar
AURMEND
I prefer to buy it but i guess ill try to make it meanwhile i find one for sale. Thanks.
Old Feb 24, 2013 | 09:48 AM
Dan Garcia's Avatar
Dan Garcia
Default requsted dimensions
pics with measurements
Attached Thumbnails STILLEN Engine Damper Brace For VQ35HR-2013_0223july19-20110004.jpg   STILLEN Engine Damper Brace For VQ35HR-2013_0223july19-20110005.jpg   STILLEN Engine Damper Brace For VQ35HR-2013_0223july19-20110006.jpg   STILLEN Engine Damper Brace For VQ35HR-2013_0223july19-20110007.jpg   STILLEN Engine Damper Brace For VQ35HR-2013_0223july19-20110008.jpg
Old Feb 25, 2013 | 09:09 PM
AURMEND's Avatar
AURMEND
can you measure the outide of the holes point to point for me? i want to make sure i have the correct size so i can be 99% sure it will bolt on thanks.
Old Feb 25, 2013 | 09:39 PM
AURMEND's Avatar
AURMEND
heres with the dimensions i got from that.
Old Feb 26, 2013 | 10:54 AM
Dan Garcia's Avatar
Dan Garcia
I'll get you measurements when I get home from work.
Old Feb 26, 2013 | 03:27 PM
Dan Garcia's Avatar
Dan Garcia
The two non-threaded holes are 3/8ths, the center of the holes is 7/16ths from any of the leading edges from the rounded ends. the third hole where the damper mounts to is 5/16ths in size and also threaded, with the hole centered 7/16ths from any of the leading edges of the squared end.
Old Feb 26, 2013 | 04:03 PM
AURMEND's Avatar
AURMEND
thank you very much ill recheck my calculations and stuff
Old Feb 26, 2013 | 04:30 PM
AURMEND's Avatar
AURMEND
final drawing not to make it and see if it fits.
Old Feb 28, 2013 | 05:59 PM
AURMEND's Avatar
AURMEND
i just have to double check the bolt holes and drill them out. Do you know the bolt size that bolts on to the engine?
Made from stainless steel.
Old Mar 1, 2013 | 05:18 PM
Dan Garcia's Avatar
Dan Garcia
13 mm. bolts the threaded part is 3/4 long.
the heads of the bolts are stamped with 116 on top and 8.8 at bottom.
the sizes of the bolts are listed on the install instructions from the link you provided.
Old Mar 1, 2013 | 06:17 PM
AURMEND's Avatar
AURMEND
hmm so it is.
(2) M8 x 35mm Hex Bolt for engine dampener
(2) M8 x 20mm Hex Bolt for block brace
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
