Oil pressure spring
Old May 15, 2013 | 07:49 AM
RodiZio's Avatar
RodiZio
Default Oil pressure spring
Has anyone tried changing or shimming the oil pressure spring for more pressure?
Old Jun 23, 2013 | 09:39 PM
johnwigs's Avatar
johnwigs
why would you need more pressure?
oil pump provides fluid volume, the main bearings are the resistance that cause pressure... if you are having a low oil pressure issue than use a thicker oil or you got a bearing issue
the spring relief is for relieving pressure near 80psi... and HR pumps move oil very well!!! so when you are near redline the pump is flowing the most oil and the engine does not need all that oil so it bleeds back into the pan
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
