Z1 VQ35HR Intake Plenum
Old Nov 30, 2014 | 11:50 AM
  #161
The_Assassin's Avatar
The_Assassin
Originally Posted by gabez33
Good mod list man, I would ditch that stillen y pipe though. I've seen it lose power on about 6 diff set ups...../ gains when switched out to HR Y or xyz
Oh it does?....It seemed to be pretty good. I Wonder why it loses power isn't it the same size as the xyz pipe?
Old Dec 1, 2014 | 10:50 AM
  #162
gabez33's Avatar
gabez33
the nismo has a 2.5 inlet? I know xyz has a 2.5 and stock is 2.0
but other than the xyz our stock Y is really good....to better improve on the OEM design megan racing has an "hr" y pipe with 2.5 inlets and 3 inch dump. Im pretty curious about it but already have an xyz. Its only 150$ and has the same design as OEM HR. It seems to me the oem HR y provides that kick and snappy acceleration...with the xyz my Z seems to have lost some kick but im sure it just shifted the power band up
Old Dec 1, 2014 | 02:20 PM
  #163
The_Assassin
No not gismo I have stillen y pipe. Inlet on it is 2.5 and out to 3 inch. I actually read in a post by motordyne that the closer the collector to the engine the greater the throttle response. Based on that theory I would think the xyz would give greater response. I was wondering also why didn't they make something similar to the hr design. Their y pipe seem much more like the de design.
"Exhaust gases can be merged just about anywhere, but in all of the testing performed on the Z, it was found that the further back from the engine the gases were merged, sound quality, throttle response and power degraded. If it was merged as far back as the rear axle, throttle response was significantly compromised. "
https://my350z.com/forum/intake-exha...roduction.html
Old Dec 1, 2014 | 03:31 PM
  #164
gabez33's Avatar
gabez33
That's a good thread, interestingly enough there's a couple people in that thread that reported the same loss of low end punch I'm experiencing... One guy actually takes it off and goes back to OEM. IDK hopefully my tune will change things
Old Dec 1, 2014 | 03:45 PM
  #165
The_Assassin
Yea thats very interesting. I am on the 4th page now will read it and look into changing from the stillen. Thanks for the suggestion. Wonder what was was motordynes response to loss in low end.
Old Dec 5, 2014 | 01:20 PM
  #166
Frostydc4's Avatar
Frostydc4
Top speed pro 1 test pipe, stillen y pipe, injen cai, z1 upper plenum, agency power single,, on that same dyno now that i made 301 a while back i shpuld be at arpund 315whp...you can look up my car on youtube if u like or view my thread
Interesting. I'm guessing most of the gains came in the midrange?
I already have the uprev tuner suite so tuning shouldnt be an issue.
I'll probably do a before & after on the 1/4 to gauge the effectiveness of this mod.
Old Dec 5, 2014 | 03:37 PM
  #167
The_Assassin
Here is the dyno sheet. Mustang dyno and yes mostly mid range. Most gains I picked was up from the retune. Last tuner didn't do a good Job.
Old Dec 10, 2014 | 06:51 PM
  #168
Frostydc4's Avatar
Frostydc4
I finally got my part. As the others mentioned it looks like a very good port job.
Attached Thumbnails Z1 VQ35HR Intake Plenum-img_0701.jpg   Z1 VQ35HR Intake Plenum-img_0702.jpg   Z1 VQ35HR Intake Plenum-img_0703.jpg   Z1 VQ35HR Intake Plenum-img_0704.jpg   Z1 VQ35HR Intake Plenum-img_0705.jpg
Z1 VQ35HR Intake Plenum-img_0706.jpg   Z1 VQ35HR Intake Plenum-img_0707.jpg   Z1 VQ35HR Intake Plenum-img_0708.jpg   Z1 VQ35HR Intake Plenum-img_0709.jpg
Old Dec 10, 2014 | 09:03 PM
  #169
The_Assassin
Nice pics bro. When are you putting it on?...Also, will you do a few runs on the dyno?
Old Dec 11, 2014 | 08:33 AM
  #170
Frostydc4's Avatar
Frostydc4
I am going to put it on when I install my headers soon. I wont be able to dyno the part separately. I am hoping to pick up a lot of power under the curve with the two parts.
Old Dec 11, 2014 | 11:16 AM
  #171
rugbyforlife's Avatar
rugbyforlife
What headers did u decide to go with?
Old Dec 11, 2014 | 11:17 AM
  #172
rugbyforlife
What headers did u go with?
Old Dec 11, 2014 | 11:35 AM
  #173
Frostydc4's Avatar
Frostydc4
I went with Stillen b/c I want to be able to run a cat just in case anything happens (I originally wanted to go with LTH's but I like being able to go under the car & change the cats in 2 hrs). From what I researched headers (PPE, Stillen, Z1) dont add much peak power but make very good under the curve power on the 35HR.
Old Dec 11, 2014 | 11:57 AM
  #174
rugbyforlife
Nice also if you went with z1 u would have to buy de test pipes since they only make one flange! No matter what people say about headers I def love mine so more power to you! Have fun on that many hour install!
Old Dec 11, 2014 | 01:03 PM
  #175
gabez33's Avatar
gabez33
thanks for posting pics, looks good
when i get mine, ill be doing a complete stock run, then add the Z1 mani and re dyno....give everyone a good idea of what this mod can do on a completely stock car
Old Dec 12, 2014 | 02:39 PM
  #176
The_Assassin
in for results. I should be getting the z1 ported lower intake plenum in january.
Old Dec 12, 2014 | 03:13 PM
  #177
Rubidium's Avatar
Rubidium
Are you also going to polish/port the lower runner to the heads too? Since you have the upper manifold off it could only help.
Old Dec 13, 2014 | 08:14 PM
  #178
Frostydc4's Avatar
Frostydc4
Thats the plan when I have another core to send them.
Old Dec 14, 2014 | 08:00 AM
  #179
The_Assassin
You do not have to send z1 a core. They will send u a ported 1 and you return the one you take off your car.
Old Dec 14, 2014 | 09:48 AM
  #180
Frostydc4's Avatar
Frostydc4
I didnt see the ported lower runners advertised on their site. I would rather buy the ported lower runners outright so I can avoid downtime with my car. Is this something you have to call and ask for?
