Differential question..
Old Mar 13, 2015 | 10:07 AM
J_don_'s Avatar
J_don_
Default Differential question..
Sorry if this in the wrong area I'm new to the forum. But I have an 08 base model 350z and I was wondering if a differential from an automatic will fit into mine? I have a 6sp MT, thanks in advance.
Old Mar 13, 2015 | 11:10 AM
Jennifer 2's Avatar
Jennifer 2
The differential pumpkin will bolt right in, but you don’t want to do this switch. The rear drive ratio for a 6-speed manual Zs is 3.538 to 1; the ratio for automatic Zs is 3.357 to accommodate the auto trans. This swap will severely hurt the acceleration potential of your Z.
Old Mar 13, 2015 | 12:51 PM
rcdash's Avatar
rcdash
^ agreed, good mod for power over 500 to the wheels though.
Old Mar 14, 2015 | 05:20 PM
ian99rt's Avatar
ian99rt
Quaife diff will be the best $ you can spend on a base HR. Second will be good tires.
Old Apr 3, 2015 | 03:09 PM
SQuaLZ's Avatar
SQuaLZ
I got a manual VLSD from a member on here last year. Installed it with Whiteline inserts and once tax season is over I will be installing the diff brace I bought. You don't realize how bad the open diff is until you switch it out.
Old Apr 5, 2015 | 11:39 PM
Wietse350Z's Avatar
Wietse350Z
So can someone explain me what the main benefits will be when changing out the OEM diff for let's say a Quaife LSD?
I never really pushed the car to extremes like on a track or something but i do know that i really need to push it to lose grip/control.
Edit: Another thing, are there any complete diff that is better then OEM for direct replacement? I believe the Nismo version has a different diff then normal versions?
I am thinking of a direct swap instead of having to split the diff and change out internals.
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
Nothing
Nov 3, 2003 01:39 PM
