Dyno tune!
Old Mar 23, 2016 | 05:23 AM
Qlitv's Avatar
Qlitv
Default Dyno tune!
I just had my car tune yesterday at fever racing and i am very happy with results. But before this run, had it dyno with just catback skunk2 true dual exhaust at 264whp. Since then i added resonated test pipes, injen intakes and osiris tune.
It base line at a surprising 291hp/238tq and after tune 310hp/268tq and what a difference, its a whole different monter.
Old Mar 23, 2016 | 06:29 PM
bealljk's Avatar
bealljk
Originally Posted by Qlitv
hole different monters
lol OP, congrats though!
Old Mar 23, 2016 | 07:54 PM
John_B's Avatar
John_B
Nice number! Their correction is a bit off at "Smoothing:0". You will find that Standard will be set at Smoothing: 5.
Old Mar 23, 2016 | 09:10 PM
Fleckerballs's Avatar
Fleckerballs
How much for the tuning and software? curious if you dont mind
Old Mar 24, 2016 | 03:31 AM
travlee's Avatar
travlee
Master
going to vary a little by area, here it is $700 for a dyno tune
Old Mar 24, 2016 | 03:53 AM
Pengu's Avatar
Pengu
Nice numbers, I'm getting my tune May 7, hoping for 300. It's all relative though, but a fun number to say.
Old Mar 24, 2016 | 07:53 AM
Qlitv's Avatar
Qlitv
Lol corrected
Thanks
Old Mar 24, 2016 | 07:54 AM
Qlitv's Avatar
Qlitv
Yup thats right!
Old Mar 24, 2016 | 08:12 AM
Qlitv's Avatar
Qlitv
Can you explain smoothing?
Old Mar 24, 2016 | 08:31 AM
John_B's Avatar
John_B
" If you look at a dynojet graph in the upper right corner, you will see where it says the correction method being used. The options are SAE, STD, Uncorrected and a few not needed for discussion. You will also notice a smooth factor (up to 5) which dyno operators use to make the power curves and any other data displayed, such as AFR, seem more ACCURATE and SMOOTH. You will also see AFR graphs scaled DOWN to hide flaws in the curve".
Most shop will set it to Smoothing 5. I bet you that numbers will be a tad different when they change the setting. Also. I'm not a full tuner expert but your AFR is at 18.10ish and that's way too rich.
Old Mar 24, 2016 | 08:39 AM
Qlitv's Avatar
Qlitv
Ok, so smoothing shows peaks and lows better depending on how they set it at?
Also air/fuel at baseline was 14.1.
During tuning he had it at a smooth 12.8/13
It was having some readings issues at the time, but he forgot to show the right afr grap at printout.
Old Mar 24, 2016 | 08:42 AM
John_B's Avatar
John_B
Correct. It's makes the jagged line much smoother. Most shop run STD Smoothing 5.
Ok good glad to here the AFR is right on the dot.
Old Mar 24, 2016 | 09:55 AM
yosip1115's Avatar
yosip1115
18:1 is LEAN
Old Mar 24, 2016 | 10:28 AM
Qlitv's Avatar
Qlitv
So i have a base model HR and the tuner say that if i get a steering wheel with the cruise control buttons he can make the launch control work with osiris but he wasn't sure.
Also that there should be a unused plug in my stock harness that plugs into the cruise control.
How accurate is that?
Old Mar 24, 2016 | 10:41 AM
John_B's Avatar
John_B
Originally Posted by yosip1115
18:1 is LEAN
Yup, you're right.
Old Mar 24, 2016 | 10:43 AM
John_B's Avatar
John_B
I'm not sure if the base has the cruise control harness behind the steering wheel. I would go with this alternative instead. http://www.npcompleteperformance.com/wotbox
Old Mar 24, 2016 | 11:06 AM
travlee's Avatar
travlee
Master
https://my350z.com/forum/2003-2009-n...o-an-04-a.html
Originally Posted by icer5160
Huge thread on this in the DIY section. If you read through the entire thing, I believe someone with an 03 was successful.
Q: Is it expensive?
A: Not really, If you already paid for an Uprev ECU flash/tune, then you can do this for pretty darn cheap (Less than $150.00 in OEM parts).
Q: How much labor is involved?
A: Not much at all. If you have a base model 6MT, just get the two supporting electronic sensors/switches for your brake and clutch pedal. Then get the OEM steering wheel controls. The wiring harness plugs are already there!
Q: Anything else to note?
A: The Base Model Gauge Cluster does not sport the LEDs for Cruise Control. With the right reflash, CC will still work with the bare minimum components mentioned above, but you won't have indicator LEDs showing this in the cluster.
Q: Can a Cruise Enabled Cluster be installed?
A: Absolutely! But the mileage for your vehicle is stored on the cluster. Thus requiring the odometer to be reprogrammed and adds more cost to this project just to have indicator LEDs. (Note: Misrepresenting mileage is illegal!)
Q: How difficult is it to replace the gauge cluster?
A: If you're a perfectionist like me, it's a PITA. The 06+ clusters have a rubberized paint coating on them that scratches effortlessly. Since the replacement cluster board I received was from a wrecker, the outer housing was completely trashed. So I had to transfer the new board into my existing housing. This was a daunting task to achieve without breaking/scratching anything and keeping dust/dirt out of the cluster. With that being said, replacement clusters can be found for around $100.00 which is super cheap compared to purchasing an OEM new one. Reprogramming fees start around $50.00 and can jump much higher depending on the shop you choose.
Q: Anything else I should know?
A: When installing the CC enabled cluster, you need to black out the SLIP and TCS cluster LEDs. Why? Because your base model Z doesn't have the supporting sensors for these features. Therefore the LEDs will be stuck on since the cluster doesn't understand wtf is going on. Not a big deal.
You can download installation instructions I put into a pdf, they detail/outline the entire process of getting CC to work without replacing the cluster:
http://s000.tinyupload.com/?file_id=...84681061546750
Cheers and Good Luck!
-Icer
https://www.google.com/search?q=add+...hrome&ie=UTF-8
Old Mar 24, 2016 | 04:26 PM
bealljk's Avatar
bealljk
Lol corrected
Thanks
Just giving you ****...you should change it back for prosperity!
onebentvalve
May 3, 2016 03:00 PM
stascom
Mar 31, 2016 04:52 PM
B Esquire
Mar 30, 2016 09:05 PM
hoangtan2013
Mar 22, 2016 11:09 AM
pettyboy69
Mar 19, 2016 11:30 PM
