Another throttle body cleaning, Surging idle thread
Long time lurker occasional poster
Ok I have done my research and there aren't many threads that seem to have been updated with what finally fixed this. Mine isn't fixed yet but will update this as it goes on. We will start with what has happened.
So to start it off I bought a stillen gen 3 intake. Decided to clean the maf, and the throttle bodies when I had the old intake taken off.
Got everything in place, and when I started my car up had a high idle. It was idling around 2000rpms then dropped to 1500rpms, and started the dreaded idle surge.
Went to my mechanic to get a relearn, since I couldn't get the pedal dance to work. He couldn't relearn it or figure out why, thought the throttle bodies looked fine. So went to the dealer to get them to do it. Said my throttle bodies were bad.
So I went up onto amazon and bought brand new throttle bodies. I installed them and went back to the dealer. They still can't program them. They told me to reinstall the old intake and bring it back, so they can diagnosis the issue.
The dealership thinks I either blew my cat or have bad o2 sensors.Now I haven't gotten a ses light at all, but it does smell like I am running rich. So I'm leaning/hoping there is a leak in the the gen 3, I have checked.
But that's where I am at will update how this goes. Oh and I haven't been driving it except to the dealer since this happened.
Update on today, I put the oem intake back on and went back to the dealership. They want to replace two o2 sensor for 1150. If that doesn't work they want to replace the cats for 2000 for parts, didn't quote labor. Lastly they want to replace the throttle bodies for 2400. I picked up my car and am going to get a second opinion.
Haha I know that price is ridiculous, 700 for parts and 450 for labor. Now on the readings, I don't know. The dealership didn't give me that information, and I didn't ask...Also pretty sure they didn't take any readings and are guessing. Is there a way for me to check that?
I did touch the butterfly valve, unfortunately I didn't read the warnings on that till afterwards. I have my ecu being looked at right now. I have read that if you touch the butterfly valve it will corrupt the ecu' s ability to read when the throttle bodies are closed. I have also read if the throttle bodies are disconnected you don't have that problem.
Advice for anyone doing to peddle dance.
DONT.
Go buy a cheap Bluetooth odb2 scanner off Amazon for $30
Connect your phone via Bluetooth to your cheapo scanner.
Then download an app called NDSIII Lite
It has an option to idle air relearn among other nice little tools eliminating the need to do the peddle dance.
this is what I did when I couldn't get the peddle dance to work when I cleaned my throttle bodies.
Works like a charm. And I don't see many other people ever recommending this. Enjoy.
DONT.
If it was just the gears, then it would work after I replaced the throttle bodies. Unfortunately there is a little more going on then me just messing up the pedal dance. I have had the dealer try the software reprogram for the idle relearn on both the new and old throttle bodies.
I replaced one of mine shortly after I got my car and was just able to bolt it on, do the air relearn and I was good to go.
I had this problem when I cleaned the TB while I had stuff apart to install a JWT popcharger on my DE. I took precautions and disconnected the battery before doing anything after reading about problems with the TB. Had a shop try to diagnose the problem. Turned out to be the ECU after replacing TB and attempting multiple idle relearns. I don't know what I could've possibly done wrong that caused the ECU to go like that.
DONT.
DONT.
It's possible the better way to do this is with the car powered on but not started and if you need to open the throttle bodies have a second person work the gas peddle.
Johnx818 sounds like we did the exact same thing, I fully disconnected the battery but didn't disconnect the throttle bodies. What did you end up doing to fix your ecu? Did you get it reprogrammed or did you replace it?
