I'm in the process of replacing my oil gallery gaskets. I forgot to take out the fuse to do the whole fuel release procedure. I've never done that before. But anyways, I've drained my coolant already and the radiator is out. Do i reinstall it and put water in? Im panicking rn. What's the fastest way to get this going, can I start the car and do the whole procedure? How long until the engine cuts off? Please help guys, I have 2 days to get this done.
Wrap a rag around the pulse damper. Loosen the two bolts holding it on. Let the pressure bleed into the rag. It's only about 40-ish psi with the car off. You're not going to damage anything or blow the car up.
Originally Posted by dkmura
Also, don't start the car when you bleed passive line pressure. I'd also recommend you to unscrew the gas cap and release any pressure in the tank.
Thank you guys so much, you saved me a bunch of headache, is it okay to put the neg back on the battery to open the gas cap? Or will that mess up something cause the maf is unplugged and a lot of other things are unplugged
