pics: 255 on 9.5+22 / 285 on 10.5+22
Old Mar 13, 2005 | 07:20 PM
apharmdb's Avatar
apharmdb
Default pics: 255 on 9.5+22 / 285 on 10.5+22
Had some folks asking to post pics of this setup. Finally got around to taking the pics. I did have to roll the fenders for this setup. Sorry for the quality of the pics, I took them in my office's garage.
Attached Thumbnails pics: 255 on 9.5+22 / 285 on 10.5+22-side_small.jpg   pics: 255 on 9.5+22 / 285 on 10.5+22-side_front_small.jpg   pics: 255 on 9.5+22 / 285 on 10.5+22-back_side_small.jpg   pics: 255 on 9.5+22 / 285 on 10.5+22-side_rear_small.jpg
Old Mar 13, 2005 | 09:19 PM
100122923's Avatar
100122923
which fenders? front ones or rear?
Old Mar 13, 2005 | 10:21 PM
apharmdb's Avatar
apharmdb
Just the rears. Fronts have plenty of room.
Old Mar 14, 2005 | 01:10 AM
100122923's Avatar
100122923
so, is the front 255 +30/+35 ?
Old Mar 14, 2005 | 05:48 AM
apharmdb's Avatar
apharmdb
Tire sizes are 255/35/19 and 285/35/19. Offsets are +22 all around.
Old Mar 14, 2005 | 06:46 AM
bstansbu's Avatar
bstansbu
Default thanks
Thanks for this post, gives me some better understanding. I am not that great with tire knowledge, but I want my rear tire to be sunken in just a fraction more than yours, so, do I go with a few mm offset more than 22 or less? I know stupid question, but please help me. BEN
Old Mar 14, 2005 | 08:36 AM
apharmdb's Avatar
apharmdb
NP, and it's not a stupid question at all. If you want the rears to be more tucked in, you'll need to go with a higher offset. Something like +30 might be what you are looking for. Also keep in mind that my rear wheel is 10.5 inches wide whereas most folks go with a 9.5 inch wheel. Good luck with the wheel search and make sure to post some pics when you get them on.
Old Mar 29, 2005 | 12:35 PM
ss350's Avatar
ss350
What brand of tires are you running? Is the lip on the 9.5 smaller than on the 10.5, or are they the same?
thanx
Old Mar 29, 2005 | 03:07 PM
apharmdb's Avatar
apharmdb
Tires are BFG KDW's and the lip in the front is much smaller than the rear. There is a 9.5 inch wheel with a lip but the offset is +12. Only seen folks running this in the rears, never the front so I don't know if it will work out.
Old Mar 29, 2005 | 04:04 PM
bwzabodyn's Avatar
bwzabodyn
I run a 9.5/10.5 setup with those exact same tire sizes (and brand) but my offsets are +29 f/r - I'm lowered about an inch, but do NOT have any rubbing issues in the front or rear (the reason I tried this setup) - it's crazy that only a 7mm difference can mean the difference between rubbing and not rubbing...
Old Mar 29, 2005 | 04:13 PM
sbcbaseball's Avatar
sbcbaseball
Wish me luck guys my tires where delivered today 265-30-19 & 295-30-19 michellin ps2,,I have the racinghart cpftune 19 inch. Front 9 inch- rear 10.5 dunno offset but i grinded the hell out of my fenders and sanded them down so looks very clean. I will put on tires this sunday ...i hope it doesnt rubbbbb
Old Mar 29, 2005 | 04:58 PM
apharmdb's Avatar
apharmdb
Should be OK if your offsets are +22 or higher. I've seen 10.5 with 295/30.19 work with +22 and cut fenders. Post some pics when you get them on!
Old Mar 29, 2005 | 05:07 PM
sbcbaseball
Will do....
Old Mar 29, 2005 | 06:15 PM
ssc's Avatar
ssc
are you lowered? do you think if you wnet 275/35 in the rear you would have to still roll fenders?
BTW i really like the 10.5 +22 because of the lip you get but i ended up ordering 9.5+22 for my rears just to be safe and not deal with the whole rubbing and rolling fenders buisness
Old Mar 30, 2005 | 06:08 AM
arizzee's Avatar
arizzee
Do you know how much clearance there is between the tire/wheel and the shock/struts? Seems that +22 offsets will rub on the outside, but I'm curious how much space the +29 offset leaves on the inside.
zland
Jun 11, 2005 01:38 AM
WP Gaston
Apr 25, 2003 09:46 PM
Driven
Dec 23, 2002 06:34 PM
zland
Nov 10, 2002 09:07 AM
