What should tire pressure be on staggered?
Old Apr 19, 2005 | 05:15 AM
VinUnleaded's Avatar
VinUnleaded
Default What should tire pressure be on staggered?
245/40/18 fronts
275/40/18 rears
Can anyone tell me what I should inflate to?
Thanks!
Old Apr 19, 2005 | 05:33 AM
JCat's Avatar
JCat
I just bot Michelin Pilots, same sizes. Discount Tire put in 40psi. (Wheels are 9.5")
Corners like a dream and I can still burn'em at will.
I'm gonna measure wear and adjust the psi if nec.
Love the tires!!
Old Apr 19, 2005 | 06:14 AM
Dave Buswell's Avatar
Dave Buswell
I have new Michelin Pilot Sport A/S. The front tires are 35psi; the rears are 32 psi. The higher pressure in the front tends to alleviate the feathering wear that can occur on the interior sides of the tires. Both Nissan and my dealer technician (for whom I have high regard) recommended those figures. My alignment is right on the mark.
Old Apr 19, 2005 | 06:15 AM
Dave Buswell
Re my previous post, I should have mentioned I have 17" wheels.
Old Apr 19, 2005 | 09:51 AM
VinUnleaded
Thanks guys, yep..Discount Tire put 40psi all around as well for me too.
Old Apr 19, 2005 | 11:43 AM
tlewis's Avatar
tlewis
I have same size setup as above. I was running 40 all around, but I was told that was a little high for street use....now I'm running 36F & 35R.
I've been on this psi setup for about 4 days now...... I'd be interested to see what psi everyone else uses.
Subscribing to thread...
Old Apr 20, 2005 | 07:49 AM
stumpmj's Avatar
stumpmj
Street: 34 psi front and rear with 245/45-18 all around. It seems to work pretty well but I might try taking out a little air to soften up the ride a bit.
Track: I try and aim for about 41 psi front and 40 psi rear with 275/40-17 all around. I need extra air in the front to keep the tire from rolling onto its sidewall, not a concern on the street.
Old Apr 20, 2005 | 07:50 AM
stumpmj's Avatar
stumpmj
I forgot to mention, street pressures are taken cold, track pressures are taken while hot.
Old Apr 20, 2005 | 08:34 AM
touringfiend's Avatar
touringfiend
I run stock tires at 45 in the front and 39 in the rear for the track. Helps with understear. On the street I run 38 all around.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
