275/35 not 30, right??
Old May 16, 2005 | 12:27 PM
Bryan H's Avatar
Bryan H
Default 275/35 not 30, right??
Just wanted to check, for19x8.5 and 19x9.5 (20mm offsets for both), the appropriate tire size would be
245/35/19 and
275/35/19
Right?
Old May 16, 2005 | 12:31 PM
2003z's Avatar
2003z
correct
Old May 16, 2005 | 12:53 PM
JimRHIT's Avatar
JimRHIT
255/35 front is better for vdc (when using a 275/35)
275/35 is correct for the rear
Old May 16, 2005 | 01:18 PM
Bryan H's Avatar
Bryan H
The car is an auto, so no VDC. Will the ABS or TCS be affected? Seems like a lot of people are going with the 245 setup over the 255, especially with 8.5" rims.
Old May 16, 2005 | 01:28 PM
LiLxDooD's Avatar
LiLxDooD
im running 275/30/19 in the rear, 35 is a little fat isnt it?
Old May 16, 2005 | 01:36 PM
Z-INCOGNITO's Avatar
Z-INCOGNITO
i have 275/30 in the back... runs fine to me
Old May 16, 2005 | 02:21 PM
Bryan H's Avatar
Bryan H
Well, if you're running 275/30 and 245/35, your front is slightly taller than the back.
245/35/19 = 25.75 inches tall
275/30/19 = 25.49 inches tall
275/35/19 = 25.75 inches tall
Old May 16, 2005 | 06:10 PM
mdracer76's Avatar
mdracer76
I've had both 275/30R19 and 275/35R19 with no noticable difference in 5mm of additional sidewall.
Old May 16, 2005 | 06:16 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
x35 will give a bit more "meat" on the tire.
Old May 16, 2005 | 09:24 PM
mucky's Avatar
mucky
check this site out http://gs.tolan-hoechst.com/tirecalc.htm
just plug in the factory tire specs and your aftermarket tire specs.
You want to be as close to factory as possible and I believe that is 245/35 and 275/35
Old May 16, 2005 | 09:29 PM
JETPILOT's Avatar
JETPILOT
INCORRECT.... 245/35/19, and 275/35/19
CORRECT..... 255/35/19, and 275/35/19
This is the only right way to do it. He didnt ask what range of sizes will work. There is one answer more correct than others, and this is the answer is above.
JET
Old May 16, 2005 | 10:19 PM
mucky's Avatar
mucky
Jet, you are INCORRECT!
The best matches depend on what size the factory tires are. Isn't the idea to be as close as possible the factory tire circumfrence, wich will equal the same revs per mile. Based on my research I found these combos to be the best:
Factory Tires---------------------------------New 19's
225/50-17 ----------------------------------245/35-19
235/50-17 ----------------------------------265/35-19
225/45-18 ----------------------------------255/35-19
255/45-18 ----------------------------------295/35-19
These may not be the easiest tire combos to come up with, but THIS is the right way to do it! As I mentioned previously, check the tire calculator site.
Old May 17, 2005 | 05:08 AM
Bryan H's Avatar
Bryan H
Thanks everyone. All very good info. There is certainly more than one combo that will work with the car. My preference is to go 245/35 and 275/35 and it sounds as though I won't have any issues.
jimster716
Sep 29, 2005 09:19 PM
PDX_Racer
Mar 26, 2005 04:55 PM
bhk1004
Feb 8, 2005 03:58 AM
mikecline
Dec 13, 2004 09:14 AM
john350Z
Mar 8, 2003 10:23 PM
