How do you use tire pressure sensors?
Old Dec 1, 2002 | 04:08 AM
z461's Avatar
z461
Default How do you use tire pressure sensors?
On new wheels? I am getting my rims this coming week and just wanted to know from those who have gotten rims already.. how do you put the sensors on the new wheels? Do they attach using silicone (that would take 1-2 days to dry), or do they attach using some other method?
Old Dec 1, 2002 | 07:32 AM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
depends on the new wheels.. supposedly volks can take the whole air nozzle assembly. but i know if it doesnt fit, you can epoxy the blue box to the inside of the wheel. it will take about a day to fully dry.
m
Old Dec 1, 2002 | 03:02 PM
z461's Avatar
z461
I'm getting Volk GT-C's... Have you heard whether or not they can take the whole assembly? Do you mean the assembly just sits in there?
Old Dec 1, 2002 | 03:07 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
the assembly is held on by the valve.
see:
Old Dec 1, 2002 | 06:25 PM
Driven's Avatar
Driven
That's the first diagram like that I've seen and it brings up a good point. I've been considering HRE 445R's for my Z, and have been told the sensors are sure to work...but I'm going to be buying reversed lip wheels (with flat lip instead of stepped). Who knows whether the sensors have to be within a certain degree of stock in order to operate properly? Since they somehow operate on the rotation (20mph min. for accurate readings)...I assume they have to be kept at a certain angle? Is this true. I'd like to be sure I know all the facts as this is a nice feature I'd like to keep and don't want to epoxy the box in and risk it jarring loose at any point.
Old Dec 1, 2002 | 06:32 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
i really dont think they have to be at a certain angle... i say this cause TXStyle has his epoxied in, and i dont think they sat there and measured any angles
m
Old Dec 1, 2002 | 06:53 PM
Driven's Avatar
Driven
I agree...he probably didn't sit there and calculate any angles...but based on the diagram, the most likely final angle if glued would be very close to what the valve stem would hold the box at when installed. Because the angle of the wheel where the valve stem insertion point is will ultimately determine the angle of the box...I'm asking this question. Since I don't want to epoxy mine, and the flush or flat barrel of the wheel I am considering will be significantly different than angle of the stock wheel...I'm trying to get better informed.
Old Dec 1, 2002 | 07:11 PM
ChinaClipper's Avatar
ChinaClipper
I believe that the angle is important only so that at 20 mph, there is enough centrifugal force generated to close a switch inside the transducer to activate the battery to activate the TP sensor. The Nissan supplier of the TPM sensors, Schrader Electronics, rates the sensor at a "10 year battery and 150,000 mile durability." I suppose that there is a certain mounting angle for the package beyond which the internal switch would not close.
Old Dec 1, 2002 | 07:17 PM
Driven's Avatar
Driven
HMMMM,
Learning more and more. I knew I liked this board.
Old Dec 1, 2002 | 07:46 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
the sensor is activated at at least 9mph.. i know this because you only need to go 9mph when registering new sensors to the controller.
anyway, i would say that the sensor could be rotated 180 degrees (with the valve stem pointing into the inside of the rim). i deduced this because the sensors are not directional.. (no left/right side designations or part numbers).
because of this, i would guess the switch operates in the vertical plane, since also that is where the centripetal (towards the center) force would be applied.
because of this, i would say as long as the sensor box is mounted with the "bottom side" (as pictured above) is flush with the rim, the sensor will work, because the switch will be activated by the centripetal force.
m
ps: centrifugal force, or by definition the force applied outward from the center is not a "real" force in physics. normally this force is explained by tension or the Normal force. these are the "equal and opposite" force to centripetal force.
Old Dec 1, 2002 | 08:04 PM
Driven's Avatar
Driven
I knew there was a reason I didn't pursue physics after my first taste of it in highschool! So, SKidazzle...could you shorten up your explaination as it might apply to me/my situation? If I don't want to glue the box to the wheel....AND I buy a reversed lip wheel (flat barrel), will the varience in the angle negate the on/off of it's intended function? Whether I rotate the box 180 degrees or not, it's actual angle relative to centripetal force will be approximately 40 degrees different (I'm guessing on that figure). AND...I'm using terminology I just learned...so don't bust my ***** if I used it incorrectly...just let me know if you understand what I mean and try to answer my question if you can.
Thanks
Old Dec 1, 2002 | 08:21 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
Thanks
wow... you are bringing back bad memories...
the amount of force the switch see is Force*cos (theta)
in the stock case... cos (90) = 1...
so in your case of 40 degrees, its Force * cos (40) which equals Force * .766
what does this mean? well the short story is the wheel will have to spin faster (create more centripetal force) to activate it... there is no way to figure out how much faster, without knowing the mass of the switch and a lot of other crap.
NOTE: as long as the angle isnt 90 degrees, (mounting the box on a "side") the sensor will work, but at higher and higher speeds required. this is because the cosine of 90 = 0.
again... this is one of those things that needs to be DONE to be sure. this is all ASSUMING the switch is perperndicular to the rim base.
m
Old Dec 1, 2002 | 10:21 PM
z461's Avatar
z461
So in basic english, how should they mount my sensor on my new GT-C wheel? It has a reversed lip I assume..
Old Dec 2, 2002 | 06:39 AM
Driven's Avatar
Driven
Sounds like the best way to proceed is as follows: Temporarily mount one of the sensors in your new wheels and just "look" at the increased angle over it's previous position in stock. Then, if it is significant you need to decide: Am I going to glue the box to the rim? (assuring similar operation to stock, but not guaranteeing it is going to stay "stuck"...could break loose and completely ruin/break the sensor) or...mount it "as is" and figure it will operate, but may require additional speed to do so accurately. At least that's my plan. Thanks all for feedback.
Old Dec 2, 2002 | 10:06 AM
z461's Avatar
z461
Thanks driven, and skidazzle..
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
