? What offset r u running?
Old Aug 3, 2005 | 07:58 AM
drumma022's Avatar
drumma022
19x9.5 , 19x10.5 +11 all around.
Old Aug 18, 2005 | 10:31 AM
Z33_SPL's Avatar
Z33_SPL
Originally Posted by Topics II
18x10 front and rear
+4 front offset -11 rear offset stock fenders
235/40/18 255/35/18 currently
Chris, any new shots of the Z? I really wanna see how flush this is on the fender. Also, what were the original offsets and what spacers are you using? I'm thinking of going 18x9.5 +20 rear with 10mm spacer so +10 and 18x8.5 +20 front with 5mm spacer so +15 effectively but I'm not sure its gonna fit.
Old Aug 18, 2005 | 02:56 PM
ppw350Zunit's Avatar
ppw350Zunit
18x8.5, 9.5, +24 offset all-around.
Old Aug 18, 2005 | 05:00 PM
SnakeBitten's Avatar
SnakeBitten
What offset would be needed for 20x9.5 front and 20x10.5 rear with appropriate tires so that it wouldnt rub or clunk with an Eibach Prokit drop? I ordered some Iforged Seneka's but am thinking of changing it to the above sizes since I read some have done this without rubbing issues....Thanks
btw is did a search and didnt get a definitive answer...
Old Aug 19, 2005 | 07:27 AM
SnakeBitten
Anybody???I cant reach Avalon Racing this week as they are away at an auto show...I would really appreciate the offsets some of you used to make the 20x9.5 fronts and 20x10.5 rears work without rolling the fender or rubbing with a Prokit drop..would really like to know before they start making the rims so I can change to the wider size...Again any help would be appreciated...
Old Aug 19, 2005 | 07:39 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I would say +30 would be fine with you. Im running a 10.5" rear slammed with 285/35 and I had to roll the fender from BARELY rubbing, so if you did +30 you should be more than fine
Old Aug 19, 2005 | 08:19 AM
SnakeBitten
Thank you Alberto What about the fronts? Is it +30 all around..
BTW your car looks incredible with that drop. Same DBZ here too ..Dont think I can go that low here in Brooklyn...roads are shyty...
Old Aug 19, 2005 | 01:44 PM
InsaneChink's Avatar
InsaneChink
ok im really confused, so the higher the offset number, the closer it is to the car?? and the lower the number the moreit butterflies out like what mexicans do?? (sorry, not to be racist or anything...)
Old Aug 19, 2005 | 07:23 PM
drumma022's Avatar
drumma022
When you go from one extrame to the other... the answer is yes. There is a range of offsets that would be acceptable for each width of wheel width.
Old Dec 30, 2005 | 06:40 AM
NJDAN's Avatar
NJDAN
would 2 19x8 (30 offset) Wolf 2 piece rims with Pirelli Pzero 245/35 tires work in the front?
Old Dec 30, 2005 | 07:10 AM
Originally Posted by MADDOG`
Alberto, Sweet wheels!!!! I see you got them from Evolution. I am not familiar with them. How was the service? Did you shop around before buying from them?
Finally, can I get some contact info for them? I'm shopping for Volks right now and based on your comments above, Evolution just might be the right place to get them from.
Then I've got to make a decision between the Volks and the Axis Reverbs (pic attached). I hear some folks have had issues with their Axis Hiros (cracking) and I'm pretty sure Volk makes a better wheel, although I bet they are more expensive than Axis.
Thanks!
The Axis Reverb is not a popular 350Z wheel, but I like the hollow spoke concept.
Old Dec 30, 2005 | 07:18 AM
Kind of. Study offset with a diagram in front of you. The concept isn’t too difficult if you know what offset is.
A wheel with a negative offset is tucked under the car. A positive offset pushes the wheel “out” towards the fenders. So when we talk about more or less offset it depends if you are talking about positive or negative numbers.
Old Dec 30, 2005 | 11:16 AM
anotheraznguy's Avatar
anotheraznguy
wow i haven't seen this one
but here is what i am running
19x9 +0
19x10 +5
245 front
275 rear
Old Dec 30, 2005 | 11:26 AM
microsteve40's Avatar
microsteve40
Know it all
I am running:
19x9.5 +30 F w/245's
19x10.5 +24 R w/275's
Old Dec 30, 2005 | 11:30 AM
350dgrz's Avatar
350dgrz
19" X 9.5" +19
19" X 10.5" +29
Volk Gram Lights 57F Pros Noble Gold
apex locator
Jul 23, 2021 02:27 AM
