Rolling the Fenders
Old Aug 12, 2005 | 12:36 PM
cotomoto00's Avatar
cotomoto00
Default Rolling the Fenders
I am installing my rims on monday. At F1 Motorsport they think I might need to roll my fenders, Do u guys thing its a good idea? or should I try to avoid it if I can, and is there any cons when it comes to rolling the fenders?
Old Aug 12, 2005 | 12:39 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
You can run the risk of chipping the paint, but other than that it will give you more room to work with
Old Aug 12, 2005 | 12:40 PM
King Tut's Avatar
King Tut
The cons are a poor fender rolling job and ruining your fenders and paint job. If you want to do it yourself places such as Tire Rack sell fender rollers for a decent price and you can charge your friends.
Old Aug 12, 2005 | 12:50 PM
apharmdb's Avatar
apharmdb
You'll always run the risk of cracking the paint, so make sure you find a good place that has experience and other customers / references you can check out. Other option is to trim the fender with a cutting wheel to avoid the possibility of cracking. I had mine rolled but the shop I went to had tons of experience and even had a chance to see their work on a Z before they did mine. Good luck!
Old Aug 12, 2005 | 01:17 PM
GQ 350z's Avatar
GQ 350z
Are you talking about Kartoyz in the bay area? I'm about to go there for my rolling neeeds. Just wondering what they charged you. Are there any other shops in Nor cal for fender rolling?
I'm trying to spend $100 or less.
Old Aug 12, 2005 | 01:19 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
what tire/wheel size config that need to roll?
Old Aug 12, 2005 | 02:27 PM
apharmdb's Avatar
apharmdb
I went to a shop in Sacramento and it was about 100.00 to roll. They did John's PPW Z before he traded it for an Evo Don't recall the name off hand but if you want it lmk and I'll dig it up for you. I'm running 19x10.5 +22 in the rear, lowered about 0.8 inch, -1.8 camber, with 285's.
Old Aug 12, 2005 | 03:05 PM
~~O8>'s Avatar
~~O8>
F1 will most likely trim the rear fenders, the fronts you basically can only shave down the the liner. If they trim the rears have them do it evenly r to l, mine were done unevenly so one side has a little more inner fender lip edge than the other. Its hard to do it yourself due to having airtools that will trim the metal off like better versus a more uneven job done by home Dremel action.
Trimming the inner edge of the fender is also better due to no possiblity of paint cracking from improper heating and rolling of the fender.
Old Aug 12, 2005 | 06:32 PM
sokudo9l6's Avatar
sokudo9l6
is your car lowered? I remember talking to chris about this and he said i shouldn't have a problem if the car is on stock height. If it's lowered...depending on which set-up you go with you may ahve to roll the rear fender. I don't recall him mentioning any problems with the front.
Old Aug 12, 2005 | 08:50 PM
GQ 350z's Avatar
GQ 350z
Yes, please find the shops name. I would much rather go to sacramento than the bay area.
ravi
Old Aug 12, 2005 | 09:16 PM
10secapsttz's Avatar
10secapsttz
I wouldnt suggest "trimming" the rear quarters.There is a pinch weld there.Get a fender roller and go slow.Very slow.
Old Aug 12, 2005 | 10:41 PM
Tantrum Z33's Avatar
Tantrum Z33
I would recommend renting the fender rolling tool at rollyourfender.com for $50 and do it with a friend. It pretty simple if you can get a friend to help hold the heat gun. Just make sure you take the time to heat up the paint and you should be fine. The whole process took me about 2 hours.
Old Aug 13, 2005 | 08:37 PM
cotomoto00's Avatar
cotomoto00
Thanks for all the advise guys, I am going to get them done at F1 Motorsport on monday the 15th, I am getting the Volks SF challenge with 275/35/19 10.5 in the rear and 245/35/19 9.5 in the front with the Eibach pro-kit. I'll let you guys know how it came out. Thanks again.
Old Aug 14, 2005 | 05:02 PM
Alberto's Avatar
Alberto
Cranky FI Owner
+1, moisture can get in between these two body panels and eventually rust. I had my fenders rolled locally for $80, piant didnt crack at all. Do a search for my post on here, it was about 3 weeks ago, I posted pics of the finished fender and tool that was used.
Old Aug 14, 2005 | 08:02 PM
sokudo9l6's Avatar
sokudo9l6
what color did you get?
Old Aug 15, 2005 | 01:24 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
how not to cut your fenders (my car)
Old Aug 15, 2005 | 04:21 PM
AzianToby's Avatar
AzianToby
Post pics of your car when you're done. I'm interested in the same set of rims. I love those challenges.
Old Aug 16, 2005 | 01:25 PM
jinsei888's Avatar
jinsei888
agreed! don't trim the rear or you'll lose the pinch weld possibly, and then ur inner fender well will separate from the outer body panel fender...YIKES! Roll it smooth and slow...make SURE the shop you go to uses a heat gun, otherwise they are clueless!
Old Aug 16, 2005 | 01:44 PM
JETPILOT's Avatar
JETPILOT
Default Mother of God !!!!!
Holy Crap !!! You butchered your car !!
What did you use? A butter knife? Damn !!!
What now?? How you gonna patch that up?
Respect
JET
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
