Rotor upgrade
Old Aug 16, 2005 | 06:47 AM
MeetJoeAsian's Avatar
MeetJoeAsian
Default Rotor upgrade
I have a 2004 non track model and I was thinking about changing out the rotors for some cross drilled/slotted. I've looked on ebay, and there are quite a few of different brands. So what's good to get, and what's not good to get? I'm sure Brembo would be rated one of the best, but other than that, what are some good brands? or are they all the same? And another thing, if I change out my rotors, I do plan to change out my brake pads too, are stock pads good for aftermarker rotors or what should I get?...recommendation?...advice anyone? thanX
I've seen them priced for anywhere frmo $150 to $500....what gives?
Old Aug 16, 2005 | 09:51 AM
sdoow's Avatar
sdoow
Check out this thread:
https://my350z.com/forum/showthread.php?t=135428
Thanks
Old Aug 16, 2005 | 10:08 AM
Alberto's Avatar
Alberto
Cranky FI Owner
www.rotorpros.com I got front slotted rotors for the track model for $100 each, no problems with them thus far....
Old Aug 16, 2005 | 02:06 PM
isugoo's Avatar
isugoo
i have one f/r set of hawk hps pads and rotora cross drilled/slotted.
its used for about 3500 miles.
i recently upgraded to brembo.
if you're interested, please pm me.
thanks.
Old Aug 16, 2005 | 02:16 PM
J Ritt's Avatar
J Ritt
We have some great 2-piece rotors for your car. They have the same vane design as our BBK's. Here's the info:
http://www.stoptech.com/press_releas...drkrelease.htm
They save a ton of weight and flow a lot more air. The replacement iron for these is under $150. Therefore, if you plan to go through a couple sets of rotors over the next few years, they're a really good value proposition.
Old Aug 16, 2005 | 04:21 PM
GMADD's Avatar
GMADD
thanks.
I was thinking of getting the same combo, how was the performance ?
how do they compare to the brembos ?
Thanks !
Tasso-
Old Aug 16, 2005 | 05:08 PM
sentry65's Avatar
sentry65
the burninator
how much weight do they save? front rotors and rear rotors?
I know how much the brembo rotors weigh, but can't find info on how much the stoptech's weigh that fit the brembos
Old Aug 16, 2005 | 05:35 PM
isugoo's Avatar
isugoo
Thanks !
Tasso-
it worked great. i installed with goodrigde lines. lines were not as expected but rotors/pads worked really well. (and of course, it looked really good)
pretty good bite and low dust and good looking. couldn't complain any but you know, i upgraded to brembo. so i took it off.
Old Aug 16, 2005 | 06:01 PM
J Ritt's Avatar
J Ritt
Sentry...please read the press release. The weight info is in there!
Old Aug 16, 2005 | 06:15 PM
sentry65's Avatar
sentry65
the burninator
thanks
that's about where i thought the weight would be
they sound nice, planning on buying some and using my stock ones as backups
Old Aug 16, 2005 | 06:27 PM
MethodRN's Avatar
MethodRN
For Sale
Sup Joe! Houston here too.
As for break rotors, look into the stage 2 from stop-tech. Comes w/ SS braided lines, pads and rotors for all 4 corners. If you go w/ aftermarket rotors that are drilled or slotted or both, stock pads will wear out to fast. Also always bed in new rotors and pads.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
