Anyone run Nismo LMGT4's 9.5" all around?
Old Sep 10, 2005 | 01:18 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
so thats what that is called never knew the term for that...
My car has 265/35/18 & 295/35/18 with the same Kumho Ecsta MX tires
It tramlines really bad...
even when I had my 245/40/18 & 275/40/18 KDW TT it did that though...
Old Sep 10, 2005 | 05:58 AM
daytona350z's Avatar
daytona350z
Originally Posted by Jason@Performance
It shouldnt rub... Ill see how close they get next time my car is in the air... but i dont think there will be a problem...
Originally Posted by Tony@Performance
that's about a 6mm difference with that kit correct? in full lock either way, i think the only thing the wider tire may hit would be the inner splash guard, on the inside front of the tire... I don't think it would really hit anything on the back-inside portion. If it does barely rub the fender liner, you can downgrade a little in tires size to maybe a 265-35-18, but then you're height ratio between the front and rear tires will be different....
yes, it is a 6mm spacer, but what the spacer does translates to about 8-10 more degress of steering angle. my experience is that i RUB the inside lower control arm with my 8.5in track rims with a 5mm spacer. i got a feeling this setup with a 9.5 front will rub badly. i really wanted to run this setup, but i dont know if it will work well with my car.
Old Sep 10, 2005 | 06:03 AM
daytona350z
pic:
[IMG][/IMG]
Old Sep 10, 2005 | 06:04 AM
350Zenophile's Avatar
350Zenophile
LOL! Yeah, I ask, b/c I had it really bad with the 245s on my Cobra...can't imagine a 265-275.
Old Sep 10, 2005 | 06:11 AM
Row2K's Avatar
Row2K
would the 9.5's clear brembos in the front
Old Sep 10, 2005 | 06:26 AM
Westby's Avatar
Westby
Default well this thread is convenient
Man was just looking for some pics of 9.5s all around, this is a lucky find. What offset is needed up front to keep it from damaging the fenders in turns, and would it still fit in the rear correctly? Would like to be able to rotate my tires and save some rubber... as well as get the handling benefits.
Old Sep 10, 2005 | 12:06 PM
Jason@Performance
Performance Nissan
Here is my thread on how to rotate directional staggard tire set up!
https://my350z.com/forum/showthread....ghlight=rotate
Old Sep 10, 2005 | 12:51 PM
Row2K's Avatar
Row2K
will these clear the brembos in the front....again
Old Sep 10, 2005 | 01:01 PM
Jason@Performance
Performance Nissan
Yes they will clear brembo's in the front...
Old Sep 10, 2005 | 03:29 PM
Row2K's Avatar
Row2K
thanks very much
Old Sep 10, 2005 | 05:53 PM
ZPirate's Avatar
ZPirate
I thought about trying this. When I ordered by LMGT4s the dealer sent me four 18 x 9.5s. I had to send two back while they sent me two 18 x 8.5s. I was afraid the rears wouldn't work on the front and I wasn't sure if you could use the same size tires front and rear so I didn't try it. The dealer didn't know they screwed it up until I called them.
Old Sep 10, 2005 | 10:00 PM
Landbarger's Avatar
Landbarger
I assume TPS will either work, or can be made to work as these are Nismo wheels as well.
Old Sep 10, 2005 | 10:21 PM
Jason@Performance
Performance Nissan
Yes... Tire Pressure Sensors work with the LMGT4's no matter which sizes you get...
Old Sep 12, 2005 | 10:50 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
I never thought that was called tramlining hehe, i call that tracking...
But N e ways, with the wider tires in front, you do notice "tramlining" a bit more yes. It's not too bad, but the wider the tire in the front, the more you will notice this.
theres one main patch of fwy on my route to work that i hit where i notice it badly, but it was terrible even with stock rims/tires, it's a 100 foot patch in two lanes of the fwy, it's just CA's crappy roadwork there....
and yes, it's my daily driver, there's no problems with driveability at all
Old Sep 12, 2005 | 04:04 PM
dc5s02's Avatar
dc5s02
Those are 18x9.5 +30 correct?
Old Sep 12, 2005 | 04:09 PM
Tony@Performance
yes, these are the 18x9.5 +30
Old Sep 12, 2005 | 06:41 PM
Speedy11's Avatar
Speedy11
Looks as good as I'd hoped. Thanks.
apex locator
Jul 23, 2021 02:27 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
