I'm about to purchase either 18x8.5 or 19x8.5 Volk TE37's what offset should I get
Old Nov 9, 2005 | 05:46 PM
Frostydc4's Avatar
Frostydc4
Question I'm about to purchase either 18x8.5 or 19x8.5 Volk TE37's what offset should I get
If I decide on 18x8.5 F+R what offset should I get front (+22 or +30) and rear (+22 or +30). If I decide to get 19x8.5 F+R what offset should I get front (+22, +29, +30, or +35) and rear (+22, +29, +30, +35)? BTW, I drive a 03 non-brembo G35C. Thanks for your help !
Old Nov 9, 2005 | 06:59 PM
1nate7's Avatar
1nate7
+22. Why not get a staggered set up of either 8.5/9.5 or 9.5/10.5?
Old Nov 9, 2005 | 09:59 PM
Triple8Sol's Avatar
Triple8Sol
I vote for 19x 9.5/10.5 staggered with +22 all around
illZ's Avatar
illZ
exactly what I have.
http://www.fairladyz33.com/gallery
Old Nov 10, 2005 | 04:19 AM
002-M-P's Avatar
002-M-P
Originally Posted by illZ
Thank you for my new background
http://www.fairladyz33.com/gallery/A...s/DSC_0522.htm
Mine should look just like that only 1" smaller
Old Nov 10, 2005 | 11:38 AM
Alberto's Avatar
Alberto
Cranky FI Owner
.....but only if you do minimum 255/285/35 series tires on them. If you dont want to run roll or cut your rear fenders then just do a 8.5/9.5 +22 with the normal 245/275 combo. I hate when guys spend extra money on the wider set-up and then run undersized strecthed tires on them. <----just my opinion
Old Nov 10, 2005 | 05:12 PM
Frostydc4's Avatar
Frostydc4
Will I rub with +22 F+R? I'm actually trying to balance the handling of the car (less understeer) and driving with the tail out does not intimidate me at all. This leads to my second question. What are the max. and min. tire widths I can use with a 8.5" wide wheel? Thanks for the help!
Old Nov 10, 2005 | 07:33 PM
Frostydc4's Avatar
Frostydc4
Also does anyone have pics of the 8.5f/9.5r staggered setup? How much do the 18x8.5, 18x9.5, 19x8.5 & 19x9.5 wheels weigh? I know they will weigh less than my OEM 18" wheels (they weighed 25lbs on my scale after I dismounted the tires ). Thanks again!
Old Nov 11, 2005 | 04:13 AM
002-M-P's Avatar
002-M-P
I know stock touring Z wheels are 26.5lbs each, not sure about the G35C wheels (I guess about 25lbs ). But the 18x8.5 and 9.5 will be between 17 and 18 lbs and the 19x8.5 will be between 19 and 20 lbs. At least this is what I have been told
Old Nov 11, 2005 | 08:57 AM
1nate7's Avatar
1nate7
19 x 8.5/9.5 +22 with 255/35 and 275/35, slightly lowered and absolutely no rubbing issues.
Old Nov 11, 2005 | 09:39 AM
ZZ33bOI's Avatar
ZZ33bOI
18 x 8.5 F and 18 x 9.5 R but too bad there not TE-37 hhehehe sooon soon to come 19's fo sho
Attached Thumbnails I'm about to purchase either 18x8.5 or 19x8.5 Volk TE37's what offset should I get-williesmalls.jpg
350z82
Oct 1, 2015 06:25 PM
