Work Wheels Thread
Old Jan 15, 2013 | 01:42 PM
  #1041
323_z33's Avatar
323_z33
Yes he says the are work wheels came of a z with 85% thread dunlops
Old Jan 15, 2013 | 04:29 PM
  #1042
mr. sparco's Avatar
mr. sparco
Looks like Work Termist TM1. What are the specs?
Old Jan 15, 2013 | 04:53 PM
  #1043
323_z33's Avatar
323_z33
They are 18x8.5 f 18x9.5 r 2 piece rims
Old Jan 15, 2013 | 04:54 PM
  #1044
323_z33's Avatar
323_z33
Would they look good on a silver z or too small
Old Jan 15, 2013 | 05:56 PM
  #1045
mr. sparco's Avatar
mr. sparco
8.5/9.5 is conservative, what are the offsets?
Old Jan 15, 2013 | 08:18 PM
  #1046
Bmurray350z's Avatar
Bmurray350z
i think it'd look alright
Old Jan 15, 2013 | 10:54 PM
  #1047
Waiz's Avatar
Waiz
Never seen those before, what are the offsets?
I have a feeling they are really conservative and you should just pass
Old Jan 16, 2013 | 10:08 AM
  #1048
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
Good eye!
What are the offsets?
Old Jan 23, 2013 | 04:25 AM
  #1049
Olliecrx's Avatar
Olliecrx
Default Work euroline DH & brembo clearance
I'm looking to buy a set of work euroline dh's but I'm unsure if they will clear the Oem brembos
Sizes are :
19x10
19x11
Both with an et of 12-15
Any help much appreciated
Old Jan 23, 2013 | 07:19 AM
  #1050
ehaalandtluk's Avatar
ehaalandtluk
Please don't get those donk *** wheels. But if you do, stoptech has wheel sizing sheets that you can print out and see if the stoptech kit will fit.
I know it's not OEM brembo, but the stoptechs are comparable in size.
Old Jan 23, 2013 | 08:12 AM
  #1051
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
What's the disk?
https://my350z.com/forum/wheels-and-...disk-help.html
Old Jan 23, 2013 | 09:04 AM
  #1052
Olliecrx's Avatar
Olliecrx
I'm ordering them from Japan so I just want to make sure i order the right disk and stil maintain maximum dish and offset etc.
I'd cry if I ordered a set and they wouldn't clear the brembos
Old Jan 23, 2013 | 09:37 AM
  #1053
VMRWheels's Avatar
VMRWheels
Brake clearance is a bit of a grey zone if you don't have the wheels in front of you, as the disk type will be one of the deciding factors. Have you messaged Work about this particular wheel's brake clearance?
Old Jan 23, 2013 | 10:44 AM
  #1054
Olliecrx's Avatar
Olliecrx
I haven't yet, I messaged a local firm that specialises in rare or hard to find wheels direct from Japan. They can get them ok, but I'm not sure if they would be too informed of the disk face variations.
I might just end up with varrstoens instead lol
Old Jan 23, 2013 | 11:46 AM
  #1055
str8dum1's Avatar
str8dum1
i would bet anything they can get, short of a custom DH will not fit a brembo.
Old Jan 23, 2013 | 12:50 PM
  #1056
driftsucky's Avatar
driftsucky
If you don't get high disk, they will not clear your brembos. Stock sizing (i.e., your run of the mill Work sizing) will not clear the brembos. I'd just toss a 5mm spacer on there and call it a day.
What are your offsets? If they're not aggressive, then you can get away with a spacer without poke and camber. If they are, then you'll have to do some stuff and some things.
edit: why don't you just tell'em you've got brembos if you're having work build them for you. that's clear all of this up.
Old Jan 28, 2013 | 02:09 PM
  #1057
Olliecrx's Avatar
Olliecrx
Thanks for the reply.
I was planning on buying a used set from a local wheel importer (similar to vrwheels for example)
I was planning on :
19x10 et12
19x11 et12 or as near as. But I was thinking if I put maybe a 22 on the front I could get a 10mm spacer
I really want to sacrifice as little dish as possible
Old Jan 28, 2013 | 02:13 PM
  #1058
AdvanZ33's Avatar
AdvanZ33
The disk size should be printed on a sticker in the inner barrels; if it hasn't been removed. Ask them to take a peek.
Old Jan 29, 2013 | 07:44 AM
  #1059
TSG-Z's Avatar
TSG-Z
+1K! Kinda interesting to hear this coming from someone in Houston, I thought loved the whole retarded *** looking trend of insanely low height on tall VIP rims.
Old Jan 29, 2013 | 10:19 AM
  #1060
driftsucky's Avatar
driftsucky
At those specs, you should be ok with a spacer. Those are a bit lower than factory but not really all that aggressive. You could get away with a spacer.
