Work Wheels Thread
Old Sep 19, 2013 | 11:26 PM
  #1161
jdmlove1's Avatar
jdmlove1
Old Sep 25, 2013 | 08:34 PM
  #1162
jdmlove1's Avatar
jdmlove1
joined the Work club.... for the winter only
Old Sep 26, 2013 | 03:23 AM
  #1163
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Nice. Those look like aggressive tires (RE-11s?) for winter...you must have a different kind of winter where you're from
Old Sep 26, 2013 | 04:52 AM
  #1164
jdmlove1's Avatar
jdmlove1
hahahahaha actually our winter and summer all the same except in winter the weather is colder (no much rain).. so in Winter our Autox season starts and thats why i kept the Kiwami wheels with the NT05 Tires
in the summer i keep back the 19 with the invos
Old Sep 26, 2013 | 04:56 AM
  #1165
350Zdj's Avatar
350Zdj
Attachment 356418
Attachment 356419
Mabrook! Looks like we got the same setup, same wheels, same tires LOL. Just different color.
Old Sep 26, 2013 | 05:00 AM
  #1166
jdmlove1's Avatar
jdmlove1
Alla ebarek feek... yeah except i got skinny tires 245/40 nt05 from previous owner.. he gave them to me with the wheels. but since they still have life, i thought of using them for few days in AutoX then change to better/bigger tires.
Old Sep 27, 2013 | 07:41 AM
  #1167
jdmlove1's Avatar
jdmlove1
Old Oct 7, 2013 | 11:10 AM
  #1168
tkuntz's Avatar
tkuntz
Ok, so i test fitted these wheels and ran into and issue that wasnt fixed by an alignment, and ideas why my driver side hub is litterally a half inch further out than the passenger side?
Here is what im talking about in the pics,
Passenger side:
Drivers side:
Old Oct 7, 2013 | 11:46 AM
  #1169
AdvanZ33's Avatar
AdvanZ33
Are the wheels being compressed?
Old Oct 7, 2013 | 04:29 PM
  #1170
tkuntz's Avatar
tkuntz
If i understand you correctly, yes they are lowered on to a stack of 2x4's and the lugs are tight also.
Old Oct 8, 2013 | 04:38 AM
  #1171
tkuntz's Avatar
tkuntz
Smaller wheels and a lower are not going to fix this issue, not to mention there isnt even a spacer on at that point and the whole wheel sits out a quarter to halg inch further which has me puzzled as to what would cause this.
Old Oct 8, 2013 | 08:37 AM
  #1172
makstraw's Avatar
makstraw
My 3pc Meisters
Old Oct 8, 2013 | 09:02 AM
  #1173
Z PHAT Z's Avatar
Z PHAT Z
Beautiful!!!! Love that color. Thinking about powder coated my gloss black with polished lips to that color.
Old Nov 3, 2013 | 03:24 AM
  #1174
dat.350's Avatar
dat.350
Default will these 18" VS-XX fit?
Im looking at purchasing some 18" Work Vs-XX wheels and trying to determine whether these will clear my brembos and fit the guards.
I have had my guards rolled and currently running some CST Hyperzero (MB battles) in 18" 9.5+15, 225/40/18 (20mm spacer front, 25mm spacer rear) lowered on BC coilovers.
Im going for a more aggressive look this time so the specs for the wheels are:
Fronts: 18 x 9.5 +7 (11cm Dish) - A DISK
Rears: 18x 11.5 +14 (13cm Dish) - O Disk
Thanks for the help!
Old Nov 23, 2013 | 05:20 AM
  #1175
RavSpec's Avatar
RavSpec
Vendor - Former Vendor
Originally Posted by dat.350
Im looking at purchasing some 18" Work Vs-XX wheels and trying to determine whether these will clear my brembos and fit the guards. I have had my guards rolled and currently running some CST Hyperzero (MB battles) in 18" 9.5+15, 225/40/18 (20mm spacer front, 25mm spacer rear) lowered on BC coilovers. Im going for a more aggressive look this time so the specs for the wheels are: Fronts: 18 x 9.5 +7 (11cm Dish) - A DISK Rears: 18x 11.5 +14 (13cm Dish) - O Disk Thanks for the help!
Will need R disk front and O disk rear to clear brembo.
A disk front will not clear.
Old Nov 23, 2013 | 04:13 PM
  #1176
AdvanZ33's Avatar
AdvanZ33
Are you sure about that? R-disc Equips did not clear my Brembos w/o a 5mm spacer...even a 3mm spacer rubbed. I've heard VS-XX require a spacer as well because Brembos weren't an option when the Equips/VS-XX were available.
Old Nov 26, 2013 | 06:05 AM
  #1177
dat.350's Avatar
dat.350
regardless if there is a spacer on the front?
Old Nov 26, 2013 | 07:11 AM
  #1178
AdvanZ33's Avatar
AdvanZ33
This is an email directly from Logan at Work Wheels during our conversation regarding R-Disk Equips not clearing my front Brembos:
You are correct, the Equip 5 spoke in 18" (since you have a 19" step rim) in R-Disk does not clear OEM Brembo on a 350Z.
The disks between wheel models are completely different, so "R-Disk" in one wheel is not the same clearance as "R-Disk" in another. In the case of the VS-XX, yes, the 350Z Brembo in 19" would require a R-Disk + 7mm spacer front. The Equip and VS-XX were both designed in the late 90's / early 00's, so it is understandable that at the time no one could predict the oversized factory calipers of today.
Old Nov 26, 2013 | 07:24 AM
  #1179
RavSpec's Avatar
RavSpec
^^ , new version of the VSXX are coming out in 2014 which will have clearance for Brembo and Akebono.
It's not officially release yet, but will be soon.
Old Jan 26, 2014 | 01:39 AM
  #1180
NZL 350Z's Avatar
NZL 350Z
Default How to... Work wheels specification chart.
I've had a quick search around without any luck. My question is.. How do I navigate around the Work wheel specs chart? Call me a noob but I can't figure out what a lot of the numbers relate to.
I'm wanting to buy a set of 18x10/11 (low offset) Meister M1 3p wheels. I've got the Brembo GT 355mm BBK front and 325mm rear. I guess I'll need R-disk front? Not sure about the rear.
A little help would be great!
