Work Wheels Thread
Old Apr 29, 2014 | 10:26 AM
  #1241
mac11wildcat's Avatar
mac11wildcat
Default Work Emotion CR Ultimate Sizes/Offsets/Tires
Hate posting threads like this but theres just so many crap threads with confusing info.
Intended wheels:
Work Emotion CR Ultimate - Matte Black
Tire sizes are negotiable but I absolutely hate the stretched tire look. This car is meant to balance looks and functionality, not scrape oil pans and have the lip fitting over the fender.
Currently stock height, planning 1-1.5"" drop with 1-2deg negative camber (that maxes out stock hardware right?)
Since this is an FI car I dont think square all the way around will work unless I can somehow fit 10-10.5's up front.
Setup 1: Staggered setup, same diameter, max usable tire size per rim and space
Front: 19x9.5+22 w/ 275 tire
Rear: 19x10.5 +22 w/ 305 tire
-will these offsets provide the "flush" look (and i don't mean in the stance flush meaning) with fenders and still be functional without too much modification?
-305s fit in the rear?
Setup 2: Staggered setup, raked front to back like Nismo's, max usable tire size per wheel and space
Front: 18x9.5+22 w/ 275 tire
-will 18x9.5+22 fit over stock Brembos?
-same tire question
-is there an advantage or disadvantage to a setup using different F/R diameters?
Open to any and all suggestions and help
Mike
Old Apr 29, 2014 | 10:44 AM
  #1242
pss350z's Avatar
pss350z
With all the camber needed to run a 275 up front your contact patch will be the width of a rubber band. But seriously, isn't it a tad overkill? Save yourslef some money on rubber.
Old Apr 29, 2014 | 10:48 AM
  #1243
mac11wildcat
Thats why Im here asking questions. Ive spent hours filtering through threads. Finding a post where someone states their wheel specs, tire specs, drop, and modifications AND includes a picture is apparently impossible to find.
The Z wont be driven all that far, so saving money on tires isnt my first concern. Definitely not looking to run excessive amounts of camber. Anything outside of whats considered functional (as in performance enhancing) camber is a no-no.
Old Apr 29, 2014 | 02:15 PM
  #1244
fataLblitz's Avatar
fataLblitz
Currently on VSTX. Gonna change it up soon and run proper sized wheels/tires
Old Apr 29, 2014 | 03:04 PM
  #1245
tbruner's Avatar
tbruner
Originally Posted by -miltdoggie-
i see the fat tire project you had going didnt last long
, You had me excited for a lil while...
Old Apr 29, 2014 | 04:05 PM
  #1246
taryon's Avatar
taryon
More pictures!
Old Apr 29, 2014 | 11:50 PM
  #1247
SerG35ei's Avatar
SerG35ei
RacingBlack, looking forward to your pictures.
mac11wildcat, check the same thread, page 53 post 1047. Hope it will help.
Old May 1, 2014 | 06:11 PM
  #1248
Rubidium's Avatar
Rubidium
My Work CR Kiwami's
Rear: 19x10.5 with 305/30/19 Michelin Pilot SS
Front: 19x9.5 with 255/35/19 Michelin Pilot SS
Old May 1, 2014 | 07:06 PM
  #1249
mac11wildcat
Originally Posted by Rubidium
My Work CR Kiwami's
Front: 19x9 with 255/35/19 Michelin Pilot SS
Just sold me on my intended setup, the same but with 9.5" in the front. What offsets?
Last edited by SR71; May 1, 2014 at 07:22 PM. Reason: please dont quot all the pics that were just posted
Old May 1, 2014 | 08:09 PM
  #1250
Rubidium's Avatar
Rubidium
Sorry I had a 9.5 front, offsets:
Front +15
Rear +12
Old May 8, 2014 | 11:39 AM
  #1251
paint3all88's Avatar
paint3all88
i will get better pictures someday!!
Old May 8, 2014 | 06:40 PM
  #1252
zedsdeadbaby's Avatar
zedsdeadbaby
Hey guys any suggestions would be really great. I have 19" work Meister s1, 9.5 + 12, 10.5 +10.. I have fenders rolled and installed spc camber arms. Lowered on h&r springs (1,3" F, 1" R) I'm ready to buy tires and with the research I have done here 245 35 19, 275 35 19 seems to be the size to go with. Not looking for much stretch. Also want to fill in my rear wheel wheel. Anyways there is a guy I no that said he has 235 35, 265 30 Tires.. I don't mind that stretch but the 30 in the rear is that correct? I believe he said that will make the wheels the same diameter. Any info please don't hold back thanks
-Jesse
Old May 13, 2014 | 10:14 AM
  #1253
jjthexer's Avatar
jjthexer
edit:intended for rubidium
Could you pretty please upload a side shot down the side of your car so I can see how much the wheels stick out? I would really appreciate it!
Old May 13, 2014 | 10:48 AM
  #1254
jjthexer's Avatar
jjthexer
Intended wheels:
-same tire question
Mike
Can you not FI with a square setup? Or were you just concerned about it not fitting in the front? Pretty sure a 10.5 in the front would fit, probably not with a 275 tire without some pull but it's already rolled so it might be close? Just curious here, because I was planning on FI "one" day but didn't know if square would cause me any problems with that?
Old May 14, 2014 | 04:00 AM
  #1255
jjthexer's Avatar
jjthexer
Originally Posted by xX Lil Oly Xx
Work ReZax II Custom Step Lip
19x9.5 -10
19x11 -1
<iframe width="560" height="315" src="http://www.youtube.com/embed/LMeyovgAsvE" frameborder="0" allowfullscreen></iframe>
This is real old, but I think I'm in love, obviously they are discontinued. But! Does anyone know a close second comparison? As far as work wheels go? I looked at VS-XX as a second, is the silver a polished? Or is it more matte silver?
Old May 14, 2014 | 05:13 AM
  #1256
terrasmak's Avatar
Intended wheels:
-same tire question
Mike
I would bump up to a 10 front and 11 rear with the intended tires. Staggering the wheel size (height) I think I cool, but up to you, gives you equal sidewall front and rear. Offset, 20 to 25 front and rear would be about right.
Old May 14, 2014 | 06:24 AM
  #1257
mac11wildcat
Are those widths possible on the Z without extreme modification to the wheel wells? I am fine rolling and doing some molding of the fender liner but I am not looking to be doing 9 points turns to avoid rubbing. Tires are just a byproduct of the wheel size which I want to be as large as is functional.
Old May 14, 2014 | 07:30 AM
  #1258
terrasmak's Avatar
https://my350z.com/forum/wheels-and-...es-thread.html please look around in here. I can turn my wheel lock to lock, no problems, I run a 10.5 front with 285/35-18
Old May 14, 2014 | 03:27 PM
  #1259
fataLblitz's Avatar
fataLblitz
Might as well post pics of the wheel setup while it's still available
Old May 14, 2014 | 10:05 PM
  #1260
350Zdj's Avatar
350Zdj
^***, that's sexy!
