Will this size fit??
Old Nov 11, 2005 | 03:42 PM
Srivero297's Avatar
Srivero297
Default Will this size fit??
for tires, 275/30/20 in the front
305/25/20 rear??
will i need to roll the fender? wheel spacers?
Old Nov 11, 2005 | 03:44 PM
ClaytonC01's Avatar
ClaytonC01
im gonna go with no on this..
Old Nov 11, 2005 | 04:43 PM
002-M-P's Avatar
002-M-P
I'm no expert, but it seems I have read that 275/35-19 front and 305/35-19 MIGHT fit. And fender would def. HAVE to be rolled. 20's i'm not sure about, but you would have to get the absolutely perfect offsets, one area I am of no help in
Old Nov 11, 2005 | 04:54 PM
Srivero297's Avatar
Srivero297
I remember a forum member telling me he has 255/35/20 and still has plenty of room without rolling the fender, and ive also seen cars with 295/30/20 on this forum.. 305 would be one size bigger...
well, if it doesnt fit, what would need to be the problem piece.. like, would it need a spacer to work, or the fender rolled, or what?
Old Nov 11, 2005 | 06:17 PM
MATTRESS MAN's Avatar
MATTRESS MAN
I have 255/35/20 up front and lowered 1.25" and room is tight, but works. On the rear I have 285/30/20 lowered 1.5" and you could definitely fit 295's maybe 305's. Actually it's the negative camber which helps the rear fit better.
Old Nov 14, 2005 | 11:16 AM
Srivero297's Avatar
Srivero297
bump
Old Nov 15, 2005 | 07:41 AM
Srivero297's Avatar
Srivero297
im more specifically concerned with the 275s in the front than the 305s..
the reason is that I already have the 275 tires
I plan on buying wider front rims (i currently have 8.5) and it would be convenient if I could slap my 275s on them rather than buying new tires.
Old Nov 15, 2005 | 08:36 PM
InSaNeZ's Avatar
InSaNeZ
275 in the front?
That's crazy!
I don't know if it would clear that metal on the inner wall of the wheel well, especially when turning as the tire will flex a little.
As for the back i don't think you'll need to roll fenders with the 305s.
Old Nov 16, 2005 | 07:57 AM
Srivero297's Avatar
Srivero297
Im gonna make a new thread that more specifically addresses the 275s in the front and Im gonna use the size in the title so its not as vague.
Thanks to those that responded.
350z82
Oct 1, 2015 06:25 PM
