Ordered the 19" Axis Seven Mod's
Old Jan 6, 2003 | 05:06 PM
wadd3456's Avatar
wadd3456
Default Ordered the 19" Axis Seven Mod's
Well folks, I am soon to be the 1st proud owner of Axis Seven Mods'. Cant wait for them to arrive.
Now for the task of picking out tires that actually FIT on these stupid rims.
245 35 19s will fit nice up front
Rears are another story. The rims are only 8" wide so it should be intersting to fit up. I may chance the 275's simply because there IS NO adequate 265 that I can find (maybe someone else can). And i dont know if 255's will be nearly wide enough.
Err. HELP!
Old Jan 6, 2003 | 05:31 PM
rodH's Avatar
rodH
can't wait to see it!!!
you could go 255/40/19
that would be the right size to NOT screw up your speedo.
255 are NOT narrow by any means, and I have contemplated getting them to help decrease rear grip (help decrease understeer) and save a little wieght over the 275.
Old Jan 6, 2003 | 05:50 PM
exa4driver's Avatar
exa4driver
why didn't you get a staggered pattern?
Old Jan 6, 2003 | 05:53 PM
wadd3456's Avatar
wadd3456
Eh they dont offer a staggered pattern. 8" is the max they make in the 1piece. The 3 piece is over 1300$ a PIECE!
Old Jan 6, 2003 | 06:41 PM
rodH's Avatar
rodH
what offset??
Old Jan 6, 2003 | 08:44 PM
droideka's Avatar
droideka
Default 255s are stout!
255 S-03 vs. 245 RE040... any questions?
Old Jan 6, 2003 | 09:13 PM
rodH's Avatar
rodH
Default Re: 255s are stout!
that pic was the visual I had when typing my reply
Old Jan 6, 2003 | 11:31 PM
StillenZproto's Avatar
StillenZproto
Wadd,
Ya finally ordered them huh ? What did it set you back in the end? When you get pics you better post them, and some closeups. Also how long you think it will be till ya get them on?
Old Jan 7, 2003 | 03:24 AM
wadd3456's Avatar
wadd3456
1430 total shipped. I did NOT get tires since I can get them locally much cheaper from a friend. They should ship sometime this week. He is just waiting on them to arrive I believe. Then they will be sent priority UPS.
OF course many pics will be coming
Offsets- i dunno, but they were ok (i was looking for them again, but cant seem to find it)
Old Jan 7, 2003 | 05:48 AM
deltaboxr1's Avatar
deltaboxr1
Nice choice of wheels Wadd.What size tires are you going with?Here is a link of the offsets, looks like 35mm offset.
http://www.axiswheels.com/se7enmod.html
Old Jan 7, 2003 | 08:27 AM
wadd3456's Avatar
wadd3456
Thanks man,
I hope to GOD he doenst send the 47mm offset!!!
Old Jan 7, 2003 | 10:45 AM
deviousZ's Avatar
deviousZ
You ordered 19" X 8" all the way around? Why?
Old Jan 7, 2003 | 01:08 PM
StillenZproto
He prob got 19x8 all around because 19x8 is the only size that the 19's come in. I am prob gonna do the same but have thought about a staggerd 19x8 front, and 20x10 rear.
Old Jan 7, 2003 | 01:20 PM
wadd3456's Avatar
wadd3456
I already wrote this.....
Old Jan 7, 2003 | 01:21 PM
wadd3456's Avatar
wadd3456
he said they can make any offset i want between 35 and 47. Sooo what should I run?!?!
Old Jan 7, 2003 | 01:32 PM
Stone Z's Avatar
Stone Z
Exclamation
35 if that's the smallest they can go. You'll be pushed in 5mm more than stock as it is with the 35mm....no way you would want to go any higher.
Old Jan 7, 2003 | 01:49 PM
wadd3456's Avatar
wadd3456
Maybe we are using different calculators but this is what I got.
Stock 7.5 w/30 offset vs my 8 w/35
The clearance from stut housing to the inside of the wheel will be 11mm LESS. The outside edge of the wheel will EXTEND an extra 1mm THIS IS GREAT
Stock 8 w/33 offset vs 8 w/35
The clearance from stut housing to the inside of the wheel will be 2mm LESS. The outside edge of the wheel will RETRACT in towards the body by 2mm
This is almost identical to stock
Old Jan 7, 2003 | 02:21 PM
Stone Z's Avatar
Stone Z
Red face
Nevermind....I was thinking you had the stock 18's, not the 17's.
My bad.
Old Jan 9, 2003 | 06:43 PM
StillenZproto
How do you think a staggerd setup would work, running 19x8 in the front and a 20x10 in the rear? ?
ablaine
Nov 29, 2016 10:13 AM
35reilly
Sep 28, 2015 07:42 AM
Tochigi_236
Sep 27, 2015 03:40 PM
