Replace rays valvestems every time I switch out tires?
Old Feb 15, 2006 | 09:48 PM
Conceyted's Avatar
Conceyted
Default Replace rays valvestems every time I switch out tires?
Well, I have had my nismo rims for nearly 2 years now. Everything is great but the time has come to get new tires. My old ones are nearly bald and have about 14000 miles on them. My question is, do I replace the rays valvestems when I replace my tires? Or do they not need to be changed out because they are metal?
I am just not feeling too good about spending nearly 500 dollars on tires (rear only) and then having to spend 40 DOLLARS! on two valve stems. Thanks for the help...
Old Feb 16, 2006 | 02:38 AM
abstrakt's Avatar
abstrakt
no need to change valve stems unless they are damaged in a way that they can no longer function properly.
Old Feb 16, 2006 | 03:53 AM
DavesZ#3's Avatar
DavesZ#3
Especially if you have TPS, the sensors are mounted to the metal stem.
Old Feb 16, 2006 | 05:44 AM
If you are buying new tires, why not add $20 for new valve stems for a quality job.
Old Feb 16, 2006 | 05:46 AM
arizzee's Avatar
arizzee
Nismo (Rays) valve stems are metal, $20 a piece, and do not need to be replaced unless damaged.
Old Feb 16, 2006 | 06:17 AM
$20 EACH!. WOW! Keep those bad boys forever.
Old Feb 16, 2006 | 06:22 AM
Chris@DTD's Avatar
Chris@DTD
There is a rubber grommet between the valve and the wheel. Make sure that you get those replaced.
Chris
Old Feb 16, 2006 | 06:31 AM
xenonk's Avatar
xenonk
yea, just the grommet. The valves are metal and they are fine and should last you as long as the life of the rim.
Old Feb 16, 2006 | 07:54 AM
Conceyted's Avatar
Conceyted
where do I get these rubber grommets from then?
and thanks for the help guys
Old Feb 17, 2006 | 06:58 PM
Conceyted's Avatar
Conceyted
bump... where can i get the rubber grommets at?
Old Feb 18, 2006 | 05:07 AM
arizzee's Avatar
arizzee
I've had two sets of wheels on my lmgt4's and didn't replace gromments..lol. I would think your tire dealers would have them. Really don't think they are needed. The stem should not be removed during tire mounting but then again I'm no expert. BTW...I have no air leaks, slow or other wise.
Old Feb 18, 2006 | 07:16 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
make sure you tell them not to replace the stem, sum dumbazz's might try? a friend at work had the bent/angled stems on his wheels. they put new ones in w/o asking. and put the wrong ones in? i dont know the whole story i just remember him saying something like this?
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
Beater350z
Sep 9, 2015 03:36 PM
AP350z223
Sep 8, 2015 04:38 PM
