I think I messed up
Old Feb 18, 2006 | 10:29 AM
etrnlderek's Avatar
etrnlderek
Default I think I messed up
I bought 57F Volk Gram Lights. 18x9.5 with a 22 offset all around. Will I need wheel spacers? Will I also be able to run 255/40/18 all around?
Old Feb 18, 2006 | 10:41 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Should've went to www.TireRack.com to get the offset before buying.
Looks like you needed a +30mm offset.
Old Feb 18, 2006 | 10:52 AM
etrnlderek's Avatar
etrnlderek
Should I bother with wheel spacers to correct the offset?
Old Feb 18, 2006 | 10:54 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I wouldn't suggest it. See if you could return them and get the correct offset.
Old Feb 18, 2006 | 10:57 AM
godmans's Avatar
godmans
Well, wheel spacers won't help you, since your problem is that your wheels are sticking too much out with a 9.5 width and a +22mm offset.
You should return them ..unless if you run some low profile tires
Indeed 255/40/18 for a 9.5 width wheel is pretty much low profile; but to be on the safe side, double check with someone who knows better
Old Feb 18, 2006 | 10:58 AM
etrnlderek's Avatar
etrnlderek
Thank you for your help
Old Feb 18, 2006 | 11:13 AM
+1. Spacers will move the wheels towards the fenders. It may seem goofy, but in effect this decreases a positive offset.
Old Feb 18, 2006 | 11:16 AM
There are a hundred posts about the potential negative consequences of running the same tires all around. Please search and read.
Old Feb 18, 2006 | 11:31 AM
1nate7's Avatar
1nate7
There are plenty of people running 9.5 +22 on the front. A 255/40 might rub in the front, but the rear fitment willl have plenty of clearance. You could still run a staggered tire set up even though the wheels aren't, 245/40 and 275/40 is the most common.
rizzla
Drag
Sep 17, 2015 08:44 AM
mytalon
Jan 30, 2003 08:55 AM
futuredeadguy
Nov 16, 2002 11:04 AM
