Widest drag radials on 17x8 wheel?
Old Mar 18, 2006 | 05:40 AM
BluZee's Avatar
BluZee
Default Widest drag radials on 17x8 wheel?
So whats the widest drag radial you could fit on a 17x8 wheel? I have my stock 17s but wanted something like a 275/40-18 drag radial. Any suggestions?
Old Mar 18, 2006 | 06:47 AM
wtf no turbo's Avatar
wtf no turbo
Stock rear 17 is a 8.5 i believe.I have tucked a 275 40 on a 8.5 but would not recommend.
Old Mar 18, 2006 | 07:05 AM
first350's Avatar
first350
I know 'corsair' (Sean) is running a 275 drag radial on his OE 17" rims...he's had them on there for more than a year with no problems. The tire buldges out a bit.
Old Mar 18, 2006 | 07:13 AM
first350's Avatar
first350
Base Enthusiast
front - 17x7.5, +30mm
rear - 17x8.0, +33mm
Touring
front - 18x8.0, +30mm
rear - 18x8.0, +30mm
Track
rear - 18x8.5, +33mm
Old Mar 18, 2006 | 08:29 AM
BluZee's Avatar
BluZee
Thanks guys.
Old Mar 23, 2006 | 12:24 AM
ZXDUDE's Avatar
ZXDUDE
well a 18" tire wont fit on a 17" rim very well...
Old Mar 23, 2006 | 05:45 AM
If you are going to the expense of drag radials, them OEM wheels are not suitable: they are too heavy. What is the point of reducing 60-foot times by 1/10 second, and increase quarter mile ET by 1/10 second because of heavy wheels.
As far as proper size, check with the tire manufacturer for reference. Bigger is not as important as proper fit.
Old Mar 23, 2006 | 03:56 PM
dlt1cy's Avatar
dlt1cy
does he already have lightweight wheels and going to use the heavier wheels instead? otherwise, i don't see how his ET would increase by keeping the same wheel and only replacing the tire.
Old Mar 23, 2006 | 04:10 PM
JG 350Z's Avatar
JG 350Z
Drag radials will always or should always be an improvement over your typical street tire track times.
Obadabot
Jun 18, 2023 11:31 PM
