Widest tire on stock 18"
Old Apr 12, 2006 | 08:31 AM
G3.5T's Avatar
G3.5T
Default Widest tire on stock 18"
What is the widest tire I can put on my stock 18" wheels with no rubbing or sticking out from the fenders? Basically I want a wider tire on my stock wheels but don't want it to look or drive weird.
Old Apr 12, 2006 | 12:37 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It shouldn't rub unless you put spacers on it AND get wider tires.
You can probably put about 245 front 265 rear. Not sure about the profile but it is probably 245/40/18 and 265/40/18 .
Hopefully some others can chime in, don't take my word as absolute.
Old Apr 12, 2006 | 01:31 PM
InsaneChink's Avatar
InsaneChink
Yup, Wired is right on... 245/40/18 and 265/40/18 is the exact set-up i have for stock '03 track rims. Front are wrapped in BFG g-force KDW 2's and rear with BFG Drag Radials.
Old Apr 12, 2006 | 01:43 PM
jcarp's Avatar
jcarp
i'ts about .35 inches shorter than stock out back but will work perfectly.
Old Apr 13, 2006 | 12:53 AM
Chad68's Avatar
Chad68
Originally Posted by InsaneChink
Yup, Wired is right on... 245/40/18 and 265/40/18 is the exact set-up i have for stock '03 track rims. Front are wrapped in BFG g-force KDW 2's and front with BFG Drag Radials.
Do you have pics of your 265's on your rears because when my factory rubber wears out, this is exactlly what I want to run as well, 245/40/18's and 265/40/18's on the stock '06 (2005 Anniversary) wheels.
Drag radials?? Do you run those sizes just at the drag track or can/do you corner with them too?
Old Apr 13, 2006 | 08:39 AM
G3.5T's Avatar
G3.5T
How does the fender gap look with the 40s vs the stock 45 sidewall?
Pics?
Old Apr 13, 2006 | 09:06 AM
trackmjt's Avatar
trackmjt
+1, I'd like to see that setup
Old Apr 13, 2006 | 09:37 AM
InsaneChink
i dont really recommend using this set-up as a daily driver, because just as you pointed out, cornering will get a bit dangerous since the tires a bit wide for the rim. So this is just my track set-up. I switch back to my Volks for daily driving. lll try to get some pics up.
Old Apr 13, 2006 | 01:50 PM
Chad68's Avatar
Chad68
Thanks, that would be great.
Old Apr 13, 2006 | 02:50 PM
Acree's Avatar
Acree
I'm running 255/40/18's all the way around on the stock touring 18's. Here's a rear shot. I don't see any reason for 265's not to fit. A friend of mine squeezed 275's on the stock 18's. I don't know how, but he did.
-Acree
Old Apr 13, 2006 | 07:17 PM
My03'G35's Avatar
My03'G35
Acree: can you take some more pics of front tires and side of the car of the gap and stuff.
and I thought the front wheels were skinner, i prob. wrong but i thought i heard that somewhere
Old Apr 13, 2006 | 08:17 PM
sq40's Avatar
sq40
What about a set of 8" wide wheels with a +17 Offset?
Old Apr 14, 2006 | 01:48 PM
Acree's Avatar
Acree
Check out this thread. It has more pics. I have Tanabe GF210 Springs installed currently. It dropped the car 1" in the front and 1.2" in the rear.
https://my350z.com/forum/media-share/184091-finally-a-sunny-day-with-a-clean-z.html
The stock touring 18's are 18x8" all the way around with a different offset for the front and rear.
-Acree
Old Apr 14, 2006 | 02:07 PM
ANXIOUZ's Avatar
ANXIOUZ
I'm riding on 245/40-18 and 275/40-18 and I think they're great. There's some room but it's not bad. (On non-stock rims though).
With a black car it's tough to see the gap as much. And since the sun never comes out here in Portland and we get so much rain, I don't really have any bright pics. I lightened these pics so that you can see what the 245/40's look like up front, 275/40 in back.
Attached Thumbnails Widest tire on stock 18"-pc310002lt.jpg   Widest tire on stock 18"-pc310003lt.jpg
Old May 6, 2006 | 09:59 AM
danstam's Avatar
danstam
With the 245 front and 265 reqar set up, do you have any vds problem?
Old May 10, 2006 | 07:11 AM
ANXIOUZ's Avatar
ANXIOUZ
I have 245 front/275 rear and my VDC is just fine. So 245/265 should be ok as well.
Old May 10, 2006 | 07:27 AM
sq40's Avatar
sq40
I am so affraid of 40 Series Tires.. Not much meat there to protect the rim..
ablaine
Nov 29, 2016 10:13 AM
