staggered or same size tires all around on base 350z
since i have no VDC i want to know what are the pros and cons of have a staggered setup vs a same size tires all around. Which one will benifit me on turns and handling characteristics. Which one is better in handling overall such as high speeds or i the rain and as well as saftey.
Thanks, I've tried doing serachs but couldnt get anything really except people flamming each other.
Ihave recently purchased 4 new oem rims from someone who upgraded to aftermarket wheels.
i am going to put all 4 rears, 2 from my car and 2 from the other z's rear. (235/50/17 with 8" rims) on my car. To me it's just silly that nissan staggered these tires. I am doing it only because i am trying to extend the life of these tires.
Same width all around will have less understeer, might make things "interresting" on a high speed bend. Wider tires are usually more susceptible to aquaplaning, but this is largely dependent on the actuall thread and tire wear.
In the end, it's personnal tastes.
I'm staggered 235/40R18 and 255/40R18 on mine.
If you want more life out of your tires, quieter running, smoother ride or better rain performance, don't use RE040s.
As far as keeping all four the same, although not common, it can be done without any adverse affects. One of the guys on here is running 275/40R17 all the way around if I remember correctly and liked that setup quite a bit.
I am currently hight staggered but my width is equal all the way around, 275/35R18F~275/40R18, so I don't get any rotating benefit but do get great front end traction.
I think in the case of the base it's up to the owner.
Chris
Chris
some magazine got a z to pull 1.0 g on a skidpad by putting 275/40/18 tires at all four corners, hotchkis swaybars, and a stronger differential. all of this on stock suspension. i cant believe this info hasnt flooded the z community, but the proof is in the pudding. http://www.sportcompactcarweb.com/pr...50z/index.html
Not much relevance to the topic, but interresting still...
^ he was asking about the pro's/con's of putting the same size tires at all four corners
They do use the same tire size all around. Adding the bars, using different offset and the rear diff make a good deal of difference too. I'm not sure what would have been the results with the tire only mods.
Color:
pikes peak white
Z/G Owner:
yes
Trim Level:
base
Biography:
i have owned 1985 300zx, 1993 300zx, 2004 350z
georgia
Interests:
target shooting / lookin at girls
Occupation:
mechanical engineer
Considering that you drive a Base, it will be fine.
pikes peak white
Z/G Owner:
yes
Trim Level:
base
Biography:
georgia
Interests:
Occupation:
mechanical engineer
bcoffee20
Nov 19, 2015 06:39 PM
DarkCreep
Oct 17, 2015 11:50 PM
Subarism
East Canada
Sep 23, 2015 06:09 PM
