I did a stupid, stupid thing.
Old Jun 2, 2006 | 08:37 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Acetone damages many plastics badly. Just a fair warning.
If you're going to use any solvent, use a tiny tiny droplet and spot check it to make sure it is not going to completely ruin your rims.
Old Jun 2, 2006 | 03:29 PM
MethodRN's Avatar
MethodRN
For Sale
Once you get it off I suggest a really good alarm w/ a tilt sensor and proximity sensor instead of using super glue on something that is meant to come off. Good luck dude.
Old Jun 2, 2006 | 05:23 PM
05-Z's Avatar
05-Z
On a ledge here....but maybe drill a small hole in the middle, and stick a screw driver in the hole and try to pop off?
Old Jun 2, 2006 | 06:37 PM
TiPIACE's Avatar
TiPIACE
yes i can see the reasoning behind glueing centre caps on - you'd rather some 15 yr old sit there for minutes wedging a screw driver bw the rim and cap trying to edge it off chipping the crap out of the wheel
Old Jul 11, 2006 | 10:58 PM
Z BOY's Avatar
Z BOY
update: took my glue problem to my local, small tire shop, and they easily popped the caps off with a large hammer, without any damage to the caps or wheels. i removed the old glue, put the caps back on, and they're holding just fine. problem solved. too bad it was beyond the skill level of my nissan service dept.
RWDBajan
Sep 17, 2015 04:52 PM
Mw870
Sep 10, 2015 07:50 PM
ares
Cleaning & Detailing
Nov 2, 2002 07:22 PM
