noob question on wheels...
Old Jul 12, 2006 | 12:20 PM
behjjeh's Avatar
behjjeh
Vendor - Former Vendor
Default noob question on wheels...
what kind offset do i need for 06 GT?
looking at GT-7 19"..
thanks~
Old Jul 12, 2006 | 12:24 PM
Advent7's Avatar
Advent7
First of all what kind of wheel width are you going to run.
Old Jul 12, 2006 | 12:28 PM
xedes's Avatar
xedes
The offset is up to you! When i was looking at the gt-7's, i think i was going to order +24 and +30 offsets.
Instead, i went with the racing hart R5 with a +26 offset all-around.
Hope this is helpful.
Old Jul 12, 2006 | 12:29 PM
behjjeh's Avatar
behjjeh
i dont know thinking about
245 front and 275 back.
do i need to roll my fender? (and what's this mean?!?)
Old Jul 12, 2006 | 12:48 PM
Advent7's Avatar
Advent7
I'm guessing your going with 8.5" and 9.5" setup. No you won't have to roll your fenders with that tire setup unless you go with a crazy offset or you lower the car. Rolling you fenders is a method of bending the inner part of the fender by a roller to fit wheels and tires on the vehicle so that when the tires and wheel are mounted on the car, they don't rub.
Old Jul 12, 2006 | 12:49 PM
behjjeh's Avatar
behjjeh
gotcha~ thanks! and that's the offset does? just for looks?
Old Jul 12, 2006 | 01:07 PM
Advent7's Avatar
Advent7
No the offset is somewhat for looks but it's the measurment that used to determine how many mm away or in the mounting surface (part of the wheel that attaches to the car) is from the center. So a postive offset let's say +30is 30mm away from the center point of the wheel width going road side. Negative offset goes fender side or inwards towards the car and 0 offset is right in the middle.
Now for looks if you want your car to look aggresive you want to have a smaller offset. Wheels with a smaller offset usually have bigger lip, but if you go to small and if your wheel width is huge you can run into problems like having the wheels stick past the fender.
If you don't understand anything about offset go to discountiredirect.com they should have images that explain it better.
Old Jul 12, 2006 | 03:08 PM
kbomb's Avatar
kbomb
pm'd you.
i have 8.5/9.5 setup.
255/285 toyo t1R tires. its the best setup on stock height. sidewall is alil thicker but with the roads around here...its a benefit.
Old Jul 13, 2006 | 05:46 AM
behjjeh's Avatar
behjjeh
wow!!! thank you very much!!
Old Jul 13, 2006 | 05:50 AM
shawnjam1's Avatar
shawnjam1
My black GT-7 are +24 and +30 offset. Lookie here...
http://www.ninjadust.com/350z.htm
Old Jul 13, 2006 | 05:56 AM
behjjeh's Avatar
behjjeh
wow!! that's nice!!!
thanks for picture!
Old Jul 13, 2006 | 06:28 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
VOLK GT-7
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
