Alignment specs
Old Jul 24, 2006 | 09:16 AM
Reefkpr's Avatar
Reefkpr
Default Alignment specs
I have been having the dreaded tire feathering problem. My Z has 19 inch volk sf-challenges with Hotchkis springs. My rear tires wore out the inside edges really fast. I purchased the SPC camber and toe kit and installed. Today I had an alignment completed and attached a copy of the printout from the alignment shop. How do these specs look for handling and tire wear. I know nothing about alignment and just want to make sure things are right. Thanks in advance.
Old Jul 24, 2006 | 09:39 AM
plastiketa's Avatar
plastiketa
It looks like the shop fixed it, but of course, its only temporary. The inside wear on your rear tires is from the negative toe, same thing happen to me. Did you get this done at Super Autobacs (this print out looks familiar)?
Is the wear in the rears premature from regular daily driving, or you have done a lot of spirited runs, canyon driving, track, etc.? I have only heard of the tire feathering problem occuring in the front tires, that's why I ask.
Old Jul 24, 2006 | 09:53 AM
Reefkpr's Avatar
Reefkpr
No the Alignment was done at Big Brand Tire. The Toe and Camber were off on the rear after changing out the rear springs. I thought the SPC toe and camber kit would correct this problem. Anyway I hope these specs will get me a little more wear from the tires. My car is a daily driver with some canyon and hard driving but mainly just a daily driver.
Old Jul 24, 2006 | 10:14 AM
plastiketa's Avatar
plastiketa
I got my car aligned after I put in my coilovers and rear camber arms, no toe bolts, and the tire wore out in 4 months, especially the inside and center! But that's with 2x canyon runs, 1x track day, and spirited driving.
Look at the rear tires from an angle in the rear to see if the tire is not pointed inward. You dont want that, especially if you are daily driving the car and want your tires to last (that was my issue).
Old Jul 25, 2006 | 06:53 AM
Reefkpr's Avatar
Reefkpr
Anyone else familar with alignments, Please review my specs and let me know.
Old Aug 17, 2006 | 06:15 AM
NISMOFO's Avatar
NISMOFO
Forgive me if I ignored your front specs, but I'm just looking at the rear.
I've had my new tires 3 months and the tread is getting thin. I'm not happy about it. I just had an alignment done a few months back. Anyways, my rear camber is 0.1 less than yours and my toe is identical. I'm thinking of having my toe in done as 0.06 in the rear this time. But being so close to the toe settings I have in the front, I'm not sure if it's a good idea.
At this point, handling can take a back seat if it's going to cost me hundreds of dollars in tires every 6 months - 1 year.
Anyone have a reason why I should have 0.06 toe in for the rear with -1.5 degree negative camber? I do have camber wear, but the overall tread on the car is much, much thinner than the front....heck my front has more camber than the rear and they're holding up better. So I think it's the toe scrubbing the tires.
Old Aug 17, 2006 | 04:58 PM
Super Avan Z33's Avatar
Super Avan Z33
it should be OK
Old Aug 17, 2006 | 05:28 PM
NISMOFO's Avatar
NISMOFO
Yep, you've got a good alignment. I found out today that my car was no longer at 0.1 toe-in for the rear, it was over 0.3 and that's why my rear tires were wearing so quickly.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
