The Hell Is Up With My Balancing
Old Jul 27, 2006 | 07:33 AM
neonsinn2000's Avatar
neonsinn2000
Default The Hell Is Up With My Balancing
ok, so got my wheels balanced.
b4 they used to start shakin at about 50mph and up.
now they start at about 75mph but only on a str8away until i take a right turn on the expressway, after that i can do 150 if i wanted to w/o any problem. but then i do a left turn on the expressway and BOOM the shakin at 55 - 75mph starts again...
can that be my alignment? this started rite after the new balance job..
Old Jul 27, 2006 | 07:41 AM
THE TECH's Avatar
THE TECH
Wheel shake is usually an alignment issue. It is also possible to get wheel hop if you have a blown shock.
Old Jul 27, 2006 | 07:45 AM
neonsinn2000
the shox dont feel bLown, just today i took a bad side of the road and it felt nice and tight not strange noice or anything like that..
and whats the deal w them only jumpin b4 i make a wide rite turn and then once i make a wide left turn its bak?
thanx man
Old Jul 27, 2006 | 02:35 PM
alignment?
worn suspension component?
wheel bearings?
Old Jul 27, 2006 | 02:43 PM
plastiketa's Avatar
plastiketa
Hows the tire wear? I forget what its called but when the tire is worn out in different spots, it could cause wheel hop. The wear almost looks like patching.
Old Jul 27, 2006 | 11:10 PM
Beaker02's Avatar
Beaker02
Are you sure you dont have a bent rim?
Old Jul 28, 2006 | 10:48 AM
Q45tech's Avatar
Q45tech
Aftermaket wheels without oem hub centric [use of plastic hub centric replacement rings]?
Old Jul 28, 2006 | 11:12 AM
simonfencer's Avatar
simonfencer
If the shake stops after a right turn and comes back after a left turn I would guess suspension or steering. I'd be taking the car to a good suspension shop to have it looked at. If you can try to isolate where the shake is coming from (like which end or corner of the car), because you might be able to see an issue if you have an idea of where to look.
Since I don't know how handy you are mechanic-wise I can suggest a few things from my own experience. Try jacking up one end of the car at a time and pulling both of that ends wheels off. Look for wear on bushings, any fluid trails anywhere that don't match side to side (that also can't be explained as water off the road). Have someone turn the steering wheel for you and make sure the steering arms are moving in similar fashions.
This might take you an afternoon to do, but probably better than paying a mechanic to figure it out for you.
Old Jul 28, 2006 | 04:03 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
tie rod ends are somewhat common on lowered cars. I already had to replace mine. Just go over everything and I'm sure you'll find out
Old Jul 30, 2006 | 04:48 PM
neonsinn2000
just chkt them out... they are fine no visible problems there
Old Jul 30, 2006 | 04:49 PM
neonsinn2000
from just lookin at them ... i cant see any bent rims at at all
Old Jul 30, 2006 | 04:50 PM
neonsinn2000
i got the factory 18''
Old Jul 30, 2006 | 04:52 PM
neonsinn2000
sounds like a plan dude...
ill try that this weeken
Old Jul 31, 2006 | 10:52 AM
NA&CH's Avatar
NA&CH
neon, sorry if i jack your thread.
I have a problem just like this its weid though. My tires are good. not bald nor off balance. The car isn't to far out of wack.
When I drive the I-state up until 75-80 the car is perfect. At 80 when i release the gas to about 1/4 throttle the car has a terrible shake. My friends mentioned that the wheel looks like a kid put it on half-asses. I just check this weekend and everything is tight and on there.
What could this be. I will be installing my coilover, and all my camber part soon. and then getting the re-aligned. So maybe it is really out of wack and I dont know it. This has never happend except on bald a$$ tires on my old car.
Thanks Guys. Sorry neon.
Old Jul 31, 2006 | 11:38 AM
neonsinn2000
no prob broman....
Old Jul 31, 2006 | 12:10 PM
simonfencer
Did you discover anything out of the ordinary?
I just thought of something else too. You might just have a bad tire. It could balance just fine (after all that is a weight thing not a load on the tire issue). I recently put new tires on my truck (old ones had a fairly good amount of tread left, but were showing a few other signs of aging). The truck stopped wandering immediately and a few odd vibrations vanished too. They were 285/75 16's on and F150, not quite a Z, but very definitely RWD. lol.
Paul
Old Jul 31, 2006 | 12:21 PM
reptile718's Avatar
reptile718
It could be several simple things. 1. They did not balance your wheels right 2. They did not tighten the lugs to spec or they are loose 3. What is the location of the balance weights? they should be closest to the center of the rim 4. If the tire has sustained any damage like potholes and such it can screw up the tire and cause vibration. Uneven tire wear or alignment issues. I know this might sound dumb but make sure they did not put the bigger tires on the front or mismatched.
Old Jul 31, 2006 | 12:46 PM
neonsinn2000
Paul
nothing dude... same "lookin" on all corners man...
could be a bad tire .... but they are about 800 miles old.. still look good as hell.. i dont dive to hard , hell... im always stuk in trafic
i dont want to end up takin it to nissan damn
HoBrahYouStink
Jun 24, 2016 10:58 PM
Paul.
Oct 16, 2015 07:34 PM
