Wheels
Old Sep 3, 2006 | 10:54 AM
Category5's Avatar
Category5
Default Wheels
Currently I have stock 2005-base 17" wheels/tires. What's the best weight-reduction I could expect by getting new lighter wheels/tires? Total 50lbs?
Old Sep 3, 2006 | 11:48 AM
bofa's Avatar
bofa
Depends on how much the new wheels/tires weigh...
Old Sep 3, 2006 | 12:32 PM
Hella's Avatar
Hella
12 lbs a wheel seems pretty high. Unless you stuck with a 17.
Old Sep 3, 2006 | 12:36 PM
plumpzz's Avatar
plumpzz
Tires. Stock tires are heavy too.. I switched from stock 17s to 20 lb wheels and saved 10lbs a wheel/tire combo even though I went wider. I saved 40 lbs. BUT, i also saved 5 lbs since i switched to duraluminum lugs instead of the heavy steel lugs. I'd say i saved between 42-45lbs said and done. Its a nice feeling arfterwords
Old Sep 3, 2006 | 12:38 PM
cavallino33's Avatar
cavallino33
Wheels are unsprung weight so taking a few pounds off of each wheels does quite a bit of good despite the fact that its not alof of weight. Its not the same as just regular body weight reduction. I don't know how much stock wheels weigh (anyone know?) but I'd doubt you could loose 12lb's per wheel.
Old Sep 3, 2006 | 02:02 PM
There are plenty of recommendations for forged 17inch wheels in the wheel forum.
Old Sep 3, 2006 | 08:36 PM
InSaNeZ's Avatar
InSaNeZ
There are many lightweight wheels available.
Check out the classified section and call up a few sponsors.
Old Sep 3, 2006 | 08:39 PM
zand02max's Avatar
zand02max
Just don't put that much air in, heck you must save serious weight by not a lot of air!
Old Sep 4, 2006 | 01:24 PM
Category5's Avatar
Category5
Thanks (it was a simple question, and you were they only one with a useful answer). Did you switch to 20lb wheels or 20" wheels?
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
